Results 1 to 3 of 3
Thread: URGENT: Info required.
    Moruya Heads/Sth. Coast, NSW
    Can anyone tell me if a clutch plate that's off an LT77 gearbox will fit the splines on an R380 gearbox and are the pressure plates the same, Thanks in advance, Regards Frank.
    near enough to...
    pressure plate and clutch plate change with the engine and application not the box.
    Spline count is the same size/diameter BUT the spigot mount changes size/length but thats not going to stop you from using the friction plate.
    Thanks Dave, Myles has done a clutch in his Disco, on his way down here now (from Canberra) to pick one up, Regards Frank.
