Results 1 to 9 of 9
Thread: transfer case sump
    Goolwa SA - but top ender forever
    transfer case sump
    I saw an photo in one of the landy mags from the uk it had an extended cover on teh transfer case to allow more oil and therefore cooler.
    They are on flea bay Land Rover Transfer Case sump .increased oil capacity
    I like the sound of them but would like to hear if anyone has any personal experience?
    they dont make all that much difference to the boxes temp but they do allow extra oil which provides a larger reserve to deal with leaks If you have the Drop down PTO on the back that provides a front and rear output the UJ for the front drive will foul on it.
    NSW far north coast
    discussed here
    LT85 Santana 5 speed & LT230
    here
    roverdrive overdrive (have to wade through a bit, there's t/case running temps discussed too, which are bit of a )
    and there was another thread but I can't find it ATM.
    I have one. They are nice and thick, well made. I dont know how much it has dropped temps, but it makes me feel warm and fuzzy
    Eastern Suburbs, VIC
    Quote Originally Posted by uninformed View Post
    What he said ^^^^
    except i know mine made no differance to the temps.... because its still on the bench!
    In theory it should lower temps, so thats good enough for me!
    1986 Range Rover Hiline
    2004 D2 TD5
    Free Again Thanks Dan
    Quote Originally Posted by PSI250 View Post
    What he said ^^^^
    Is that why i havent noticed a change in mine yet as its still on the bench as well waiting on a drill and tap
    Quote Originally Posted by rangieman View Post
    For extra drain? No need.
    Feb 2012
    I have tapped the back cover and placed a fuel/oil pump on my t case that is controlled with a switch in the cab. Switch in every so often and it squirts oil to the input gear (I don't have the cross drilled one) And viola better t case life span.
    Bacchus Marsh Vic.
    Maybe send Urban Panzer a PM as he fitted one.
    His how to thread on his site has most of the details, Discovery2.co.uk
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
