Thread: 2007+ L322 Buyers Guide
    Kiwiland
    Hi Guys
    A relative is interested in a used L322, probably 07+ vintage.
    Does anyone have a good buyers guide for these? Things to check, things to avoid, factory options you definitely want etc?
    This will be diesel, most likely the 3.6 V8. How are these holding up?
    Dougal
    Mar 2007
    Birnam Range, qld
    Hi mate, whilst there is no place quite like aulro, ffrr.co.uk has all the info you need, great site.
    TDv8 is a great engine by all accounts.
    neil
    Jul 2008
    Cheltenham, Vic
    Quite a few that we looked at were really tatty inside, some of the trim like armrests etc does not seem to hold up anything like as well as on the earlier years even at reasonably low KMs.
    There weren't many options I don't think, worth sticking to looking for the Luxury spec level on the diesel though as it doesn't seem to make a great difference to the price now. The heated/cooled seats are vaguely nice to have and if you want the factory fitted aux input for music it only came with the rear seat entertainment fitted too for example.
    We ended up going with a supercharged petrol though, the economics of the extra cost to buy a TDV8 didn't work with the sort of KMs we do on it.
    Nov 2008
    they are a all round very good reliabe car,, biggest complant we get is wind noise from the plenum seal, other then that, id buy one no doubt
    Queensland
    supercharged petrol is only one to get rear e-diff ("locker") as standard too - very rare on TDV8 - so if you intend using it offroad its something to be aware of
    Kiwiland
    Thanks guys. The most offroad this would get is fishing, I don't see it being overtaxed doing that.
    Mar 2010
    Gippsland
    plenum seal noise
    Quote Originally Posted by stig0000 View Post
    i just happened accross this comment and immediately thought this Plenum seal noise could be what that dreadful buzzing noise is comeing from the dash at about 100km/hour/ ????????
    Our RR is a vogue V8 2003. do they have plenum seals and if so and this is the noise , can it be dealt with ?
    sorry to chnage th subject , but thought id jumo on this quickly and maybe fix an annoying problem.
    thanks
    Jan 2012
    Geelong Vic
    Buzzing
    Hi Danske
    Suggest you check the windscreen mounting seal, I recently had windscreen replaced and immediately had very loud buzzing noise at 100k.
    Took it back to O'Briens - problem gone, not sure what they did but probably added some flexible sealant to the mounting seal. May pay to check with your local glass dealer.
    Hope this helps
    Peter
    May 2011
    Angry hornets at 80+ kph
    Hi Danske,
    The early L322's (2002-2004) had a sporadic issue with the seals around the windscreen not setting properly with the sealant. This meant that over time, particularly in our warm environment, they lifted away from the screen allowing the edge at the base of the windscreen to vibrate when subjected to wind flow across the base of the windscreen.
    A nice run of Sikaflex across the seal along the base of the windscreen worked a treat on mine. Over three years ago since mine done and not a hornet heard since.
    Hope this helps. (sorry to hijack thread folks).
    Iain
    Iain
    VK3BIT
    03MY Range Rover HSE Td6
    Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
    LROCV DTU member
    Kiwiland
    Quote Originally Posted by neil 90 View Post
    neil
    Turns out that website is fullfatrr.com
