Results 1 to 10 of 18
Thread: What would blow off a TDi300 rocker cover??
    It'sNotWorthComplaining! Guest
    I was asked this, a guy had his rocker cover blow off his 300TDi.
    What would do this Excessive crank pressure? Leaking rings?
    Diesel in sump oil causing high level and crank case pressure?
    opinions welcome
    Jan 2010
    Newman WA
    How about defining this rather emotive description of "Blown Off"? Blown off should indicate that is no longer in its original place ,like all 4 bolts have snapped and the cover and the sound cover , breather assembly are no longer there. or is it that the sealing arrangement has simply been forced out ot position ? for whatever reason ?Sounds like the standard blown head gasket to thr push rod tubes/holes
    Quote Originally Posted by 400HPONGAS View Post
    The email i received was blown off and snapping a rocker cover bolt in the process. I have seen the vehicle myself
    Further info this morning is the oil level is higher and oil is very thin.... sounds like the fuel is getting in to the oil
    if that is the case I guess they are lucky it did not start to run away on its own juices.....
    Safety Bay
    Lift pumps filling the sump with fuel. Pat
    Dec 2008
    blackbutt qld
    A V8?
    Quote Originally Posted by blackbuttdisco View Post
    A V8?
    no V8, were talking tdi300
    RDX, C4, ANFO, Cemtex, Detcord, black powder, smokless powder, cordite. Just some of the things that Could blow the rocker cover off of an engine.
    Sep 2011
    newcastle
    Quote Originally Posted by PAT303 View Post
    Had this happen to a boat in the marina I work at and the engine was essentially on fire internally and kept on running . Couldnt shut it off . A mechanic was there at the time and managed to shut it down somehow but I dont know how .
    It was running seemed like flat out and smoke everywhere and I mean everywhere . Was a perkins diesel !
