Results 1 to 8 of 8
Thread: V8 alternator connection, re-crimp or not?
    I thought I had a spare alternator, turns out the connection on the back is different to mine.
    The existing alternator has one large spade in the middle and one smaller one either side., (2 door, 3.5 carby).
    The alternator I have to swap it with has two large spades, middle and left, and one small spade right.
    I was wondering if I should/could cut/crimp new connectors on the wiring harnes, if so what goes where?
    maybe I should just not stuff about
    anyone want to swap
    WA
    Need photos!!! (Makes it easier, anyway.)
    At any given point in time, somewhere in the world someone is working on a Land-Rover.
    the first 2 are the existing alternator and plug.
    What I have to replace it is the alternator with the two large and one small spade connector. The mounting bolt holes are fine.
    So, can I just cut the plug and crimp on spade connectors?
    If so which will go where?
    BTW the replacment alternator is from 2 door RRC too, must be a different year.
    bumpy bump
    chrisl Guest
    Hangover,its a type 1 and a type 2 Alternator connector if you have a look at google books for "classic British car electrical systems" you'll find the pin outs and how to do it.
    WA
    The third photo shows what I've got. The little tab is for the warning light, and the bigger ones are for the output. An auto sparky told me that there are two so that you can run two big wires which woud run cooler than one big wire.
    you should also find that the 2 bigger spades are on different phases of the out put so that you can use it as a very effective dual battery system..
    one spade to each battery with the excite coming off of the primary starter.
    the small spade should be the excite to work out which of your 3 in the plug does that probe for 12V with the ignition on, the big one will show 12v regardless of the ignition setting and the smaller one that provides the excitation or sense should only show 12V when the ignition is on.
    You dont need to recrimp with a jewlers screwdriver you should be able to free the prong of the existing spade connectors from the plug pull the spades out the back then just push them onto the spades in the housing.
    thanks for the help, but I was just offered a suitable replacement that should "Just fit"
    Thanks Brute !
