Thread: difference between LT77 or R 380
    Perth - WA
    Whats the differnece betwene these two boxes?
    And what would be the best behind a 200TDi and infront of a Series 3 transfer case and vehicle ? (mated via an ashcroft conversion kit)
    cheer
    Jim
    May 2008
    Bundaberg Qld
    East-South-East Girt-By-Sea
    1.20 MB
    The R380 is 30mm longer than the LT77, but if you can find an R380 off a 200Tdi Defender they are shorter than the Disco version (and the selector mechanism/gearstick is in the correct place for the Series/Defender shape.)
    The 380 is better
    The Lt77 has a problem with the lay shaft that gives them back lash. Seen people send thousands to fix the box only to have the same problem 4 months later on. Although saying that I have had a few LT77 and still good boxes once you get used to the back lash but if given the choice I would go for a R380
    Ali
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    The LT 77 is not quite as strong and has reverse up alongside 1st and the R380 has it under 5th.
    As far as I am aware, in Aust the R380 was not fitted to the 200tdi - was introduced with the 300tdi and serpentine 3.9 in the discos/defender.
    So the LT 77 will definitely fit a 200tdi - but the R380 is a better box. As indicated the Defender version has a shorter bell housing.
