Thread: my throw-out bearing sounds like a chopper
    Feb 2009
    hi, just look for some clarity.
    After a road trip at xmas I noticed a sound coming from under the car like some distant army helicopters. The sound fades in and our and doesn't increase or decrease with a rev of the motor. If I push the clutch in, it goes away. Sometimes I can hear an audible spinning sound a bit like a worn bearing. instead of the chopper noise. Is this a through out bearing? Any thought appreciated.
    Jason
    2010 130 TDCi
    nasty noises
    Quote Originally Posted by newhue View Post
    --- I noticed a sound coming from under the car like some distant army helicopters. The sound fades in and our and doesn't increase or decrease with a rev of the motor. If I push the clutch in, it goes away. Sometimes I can hear an audible spinning sound a bit like a worn bearing. instead of the chopper noise. Is this a through out bearing? Any thought appreciated.
    Does the noise disappear when you select 4th gear?
    As that is when the mainshaft is direct coupled with the output shaft and reduces the load on the layshaft bearings.
    My R380 is about to be pulled out and rebuilt to get rid of the potential of another apocalypse now, with choppers!
    Ipswich QLD.
    If it was the throwout bearing, I would expect it to make a noise when the clutch pedal is depressed. That is when it is doing the work.
    Cheers, Mick.
    1968 SIIa SWB
    1978 SIII Game SWB
    2002 130 Crew Cab HCPU
    Australia
    In general,
    Clutch pedal in and noise heard = throw out bearing
    Clutch pedal out and noise heard = Gearbox input shaft bearing
    Central Coast NSW
    Pressure plate springs are known to rattle on PUMA's.
    Without hearing the noise, it may be worth considering.
    Rayngie Guest
    Only Landrover can come up with a part called 'Throw out' ...and expect it to work,
    Central Coast NSW
    Quote Originally Posted by Rayngie View Post
    “Throw-Out bearing” or “Thrust-Race” is standard terminology for this part across all of makes of vehicles.
    Jun 2008
    Drouin East, Vic
    Quote Originally Posted by strangy View Post
    In general,
    What he said.
    Feb 2009
    yes guys it is when the clutch pedal is pushed in.
    Do they fail un-expectidely or just get noisier. I have another 5K before the next scheduled service
    thanks for your knowledge
    Jason
    2010 130 TDCi
    Australia
    Not common for them to fail unexpectedly.....in that, if they have been subjected to lots of water, or foot resting on the clutch constantly, city vs country driving...it isnt unexpected.
