Thread: Battery Tray
    Mar 2009
    Near Geelong, Vic.
    Battery Tray
    I'm fitting this now.
    Can someone post a picture of the hold-down device that stops the battery flying down the road under brakes?
    Mine had an okkie strap.
    I can make one no problems but if I'm putting the resources in, I may as well make it orig rather than going off on a tangent like I did with the gear box crossmember.
    Perth WA
    Quote Originally Posted by geodon View Post
    I see no one has yet, so here's a photo of mine. It's just a 1/8" angle iron contraption which provides all the security you'll need.
    Make it of reasonable dimensions so that it'll fit most any battery size.
    Jack
    I used to be indecisive, but now I'm not so sure.
    1971 Landrover S2A Station Wagon
    1917 Model T Ford Lt Ptl Car (under restoration)
    1953 Austin Champ (under restoration)
    Mar 2009
    Near Geelong, Vic.
    Thanks, Jack but I had already started!
    I worked out where the hold-downs were & made it very simple to take advantage of modern no-maintenance batteries.
    What is the bracket with the two holes for?
    Does it face forward or back?
    Dec 2008
    Very hard to tell from small photos, but I have always taken the standard battery tray, forward of air filter, drivers side, and put a transverse cut in the sides, and welded in extension pieces (about 60mm from memory) to enable an N70ZZ size battery to fit. And then just use supercreep hold downs.
    Cheers, Andy
    Mar 2009
    Near Geelong, Vic.
    Dunno re photos!
    Try right click then "open in new window"
    Loganlea Qld
    Looks like the mount for the horn.
    Glen
    1962 P5 3 Ltr Coupe (Gwennie)
    1963 2a gunbuggy 112-722 (Onslow) ex 6 RAR
    1964 2a 88" SWB 113 251 (Daisy) ex JTC
    REMLR 226
    LWB123 Guest
    Hello from Brisbane.
    On my SWB S3 there is a similar, but not identcal, plate at the front of the carrier frame with two holes that hold the horn - someone else has also suggested this. An ignition relay also bolts on to the side of my battery carrier.
