Results 1 to 10 of 12
Thread: Discovery 2 Bottle Jack
    Dec 2009
    Hampton Park
    Hello,
    Can the Disco 2 bottle jack be repaired, or is it time to get a new one??
    It's leaking and won't fully raise when weight is on the jack.
    Jason
    Somewhere else, QLD
    I'm reasonably sure the Disco2 has the same jack as the Disco 1 -
    There have been a number of threads about re-building the top and bottom seals.
    However, it may be that your jack only needs a refill ( look in the oil section at many auto places) and a tighten of the pump pedestal ( Circled in the green). Two of my Disco Jacks leaked here. The solution was to unclip the linkage and, using a big spanner or shifter giving the top section about 1/12th a turn/half a flat. The washer is metal not rubber here, so I don't know why it has leaked at that point. Also, sometimes air pressure builds up in the reservoir, and you have to gently massage the rubber bung to let the air out. ( If you re-fill, tread carefully removing the bung as a replacement can be hard to find).
    Dec 2009
    Hampton Park
    Hello, back again.
    The leak appears to be coming from the area where the lifting ram comes out of the housing, thats why I was asking about the serviceability.
    I did use the search but it came up with na da ting.
    Jason
    Douglas Park, NSW
    Quote Originally Posted by Jason789 View Post
    The tutorial is in the 'files' section (button in top olive menu bar).
    http://www.aulro.com/afvb/local_link...catid=2&id=129
    Dec 2009
    Hampton Park
    Thankyou,
    Jason
    Feb 2011
    Lockington, Victoria
    Angry replace it
    far easier to just buy a new one............jack repair shop wanted $60 to look at it, $120 to repair it and a full seal kit about $60 aswell, NEW heavy duty bottle jack $59
    Mine did this as well, as did the replacement! I figured it was because of the way it lies in the cradle, so the second replacement now lives in the storage boxes in the back. (I this the replacement was around $35 on special!)
    Matt
    Peters1 Guest
    Where to get one
    Where can you get one
    Jan 2012
    Manly, NSW
    Yes but to be honest, I started the process then picked up a 3000kg small trolly jack for $60. Yes bigger to carry around but it sits quietly on it's back in the boot taking up not too much space. I feel more comfortable having it too as it's capable of lifting the whole car in theory not just one side/corner.
    If i know im going where the ground is soft I also take a small piece of plywood to put it on.
