Thread: Cdl switch?
    wmd Guest
    Cdl switch?
    Hi all
    my cdl light won't light up when I engage the cdl ?
    I connected the plugs from the switch too each other and the light works.
    When I jacked up one wheel and put it in neutral and pushed the leaver to lock it all worked fine.
    My question is could the cdl not be engaging 100% or is the switch shot?
    Any one with experience in this area ?
    Cheers WMD
    Mar 2010
    South Africa
    Sounds like the switch isn't adjusted properly or else yes, it's a gonner.
    wmd Guest
    how is this switch adjusted?
    or is it just easier to buy a new one?
    cheers wmd
    Mar 2010
    South Africa
    It screws into the housing and has a lock nut.
    Remove the switch and see if pushing the plunger engages the light.
    If so, then the switch is 100%.
    To adjust.
    - engage CDL
    - loosen lock nut
    - screw switch housing in until light comes on
    - tighten lock nut
    - disengage CDL and make sure light goes off
    - done!
    wmd Guest
    Thank you that's just what i needed to know.
    Cheers WMD
