Results 1 to 10 of 14
Thread: 15inch Rims on Defender?
    JC Rover Guest
    I'm in the planning stages of rebuilding my defender (not sure where the money is coming from). Would a 15 inch rim fit on the defender? Would there be any benefit in having 15 inch rims? If they do fit, I would think there are more tyre choices for 16 inch rims. Currently running Coopers ST 235/85 R16 on Boost alloys. Could you powder coat boost alloys black? That would look cool too. I really just want something a bit wider and taller and black.
    Kingston, Tassie, OZ.
    15's usually require a shaving of the OD of the disc backing plate to clear, but not all rims require this.
    Whats wrong with Wolf 16" rims?? At least they are original LR
    JC
    Feb 2010
    Townsville
    im running 33 12.5 15 MTZ micky T on my defender. only thing you have to be carful is rubbing on the control arms, which is easy fix by putting in a adjustable drag link bar, if you want to run that size. 10.5 are all fine
    Cool 15 inch
    i use an old set of 15 inch yoko geolander AT around home after it has been raining as the usual road skinnies chop the grass up. Slightly smaller than the 750's but don't drive far on them other than to the tip. work well and don't dig in.
    Central Coast NSW
    Quote Originally Posted by JC Rover View Post
    My son just had his WRX wheels (17x7) powder coated, cost $120 for the sand blasting and $220 for the power coating in pearl white.
    Came up a treat.
    Fremantle
    I have 15x7 inch rims running 31x10.5 15's and work well no probs. Plenty of cheap tyre choices in this size. I'm looking at getting BFG km2's in 33x10.5 15's but quite hard to find and exxy in Aus. Have looked into getting from Tirerack in US an much cheaper.
    I like the 15's over the 16's as I feel there is more bag in the profile when the pressure is lowered esp in sand.
    Fremantle
    Sep 2006
    Northern Beaches
    I have some 15 x 8 Dynamic rims with 33-12.5/15 KM2s and they don't have any problems with rubbing, although I don't have them on all the time. 15 inch tyres are often around $80 cheaper than 16s.
    Jeff
    Mar 2011
    Quote Originally Posted by Drover View Post
    Came up a treat.
    Drover is that total or per wheel? If its total that I'd very cheap.
    I have 15x8 dynamics on my 90 with 35x12.5 r15 tyres. no rubbing with 3 inch lift and -25mm offset.
