Hmmmmm .... ratchet spanners ...![]()
Did the TD5 water pump today.....thank god for ratchet spanners is all I have to say.
If only they had of made the impellor shaft 2-3mm shorter, it would have been an easier job!
Good result though, the old one didnt have much life left in it at all.
Kev..
2014 Isuzu MUX LST with fruit
2008 Isuzu D-Max
2015 Kimberley Kamper "Classic"
Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
The good Lord himself designed ratchet spanners!!
Fluids.
How do you find your provent?
Now the water pump is done I need another project!
Just wondering how long the water pump lasted?
I got the disco off my uncle 2 years ago, he had it since new, he hasnt had it replaced. Its done 165K now.
So not bad going. The seal failed on it.
So why do people make it out to be replaced regularly??
Just wondering what year TD5 you have?
My original water pump lasted 9yrs 100k km(bearing seal) replacement cheapy lasted 3yrs 30km (casing o ring seal failed).replaced with genuine last week.
Much easier job second time as I had ratchet ring spanners.
Kev..
2008 Isuzu D-Max
Timely post - I've got a water pump there to replace, and have been pondering the purchase of a set of ratchet spanners. Looks like its a goer.
I've got a leaky manifold, and a few oil leaks on that side anyway, so seemed an appropriate time to replace the pump.
For comparison, mine's done about 185k and is the original, and seems to be leaking both coolant and I think power steering fluid as well.
