Results 1 to 10 of 19
Thread: Would you replace these bushes?
    Sydney, NSW
    As the title guys, or the rear control arms on a 2006 defender (original bushes)... This is with the car level, can easily get 5mm plus gap between bush and chassis with smallest bit of flex.
    Thoughts please.
    Sent using Forum Runner
    Regards,
    Jon
    Kingston, Tassie, OZ.
    Jon,
    Those bushes are well due to be replaced, the first pic seems to show that they have even dropped in the centre 'guide'.
    You'll notice that if they get any worse, the vehicle will start throttle steering, as the rear axle pushes forward under load and drops back on a trailing throttle.
    I'd chuck 'em.
    JC
    Apr 2007
    Northern Hunter Valley,Dungog Shire
    I agree with Justin. They are well past their useby date. I would expect you will find an improvement in steering which you may not have noticed deteriorating over time. Cheers, 130man.
    Sydney, NSW
    Thanks guys. That's pretty much what I thought.
    Another job for the to-do list.
    I'll probably do the other end at the same time too.
    Thx
    Jon
    Regards,
    Jon
    Feb 2010
    Deloraine, TAS
    Mine are in similar state. I have replacements but haven't done the job yet.
    Simon
    95 Defender HCPU 130
    JDNSW's Avatar
    Yes.
    Apr 2012
    Whyalla, SA
    No jack or anything required...
    Do one side at a time...
    Whole job for front bushes only about 20 minutes....
    May 2002
    Heathcote (in "The Shire")
    And I bet they have all separated into their component parts.
    Martyn
    Sydney, NSW
    Ok, so rear trailing arm bushes (4 in total) to replace...
    Would you do the front radius arm bushes (6 in total) at the same time? After-all, they've been in just as long and have gone everywhere the rears have!
    Next question, for those that need pressing in, Superpro with no press or genuine with press???
    Thx
    J
    Regards,
    Jon
    Quote Originally Posted by Yorkshire_Jon View Post
    Thx
    J
    My PERSONAL preference is genuine ONLY.
    JC
