Results 1 to 8 of 8
Thread: EGT sensor location
    Dec 2011
    Me!bourne's West
    EGT sensor location
    Hi all.
    As i have the head off the Td5 i would like to install the VDO pyrometer that i have bought.
    After reading many threads on these i have found that some people have fitted the thermocouple to the blanking plate for the EGR at the end of the manifold and some have welded a boss onto the exhaust dump pipe.
    The blanking plate would be the easiest place to put it but i dont think it will give an accurate reading in this position.
    I think the dump pipe is best but unsure of the correct location.
    Any pro's,cons or tricks for beginners?
    Does anyone have a photo of a dump pipe mounted thermocouple?
    Many thanks
    R2
    Oct 2011
    Fremantle WA
    Quote Originally Posted by R2D2 View Post
    Hi all.
    Many thanks
    R2
    Thanks R2. Ironically I'm wanting the same question answered - despite having read any number of related posts on this site.
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Hi Guys. Have a read here this may help.
    ThermoGuard Instruments
    Gary
    the best place to put the EGT sender is in the middle of the manifold before the flange that the turbo bolts onto.
    Feb 2011
    Hobart, Tasmania, Australia
    Blknight is correct.
    However, that requires your manifold to be drilled and threaded and only gives a short space for the probe to go in - my probe is twice as long as what that would allow.
    I'd go with the blanking plate, you can buy these already with a hole and threaded. This gives you a reading close to the exhaust ports for at least the first two or three cylinders.
    In the dump pipe is further down the exhaust system and after the turbocharger, so would be less accurate as a reading of the cylinder temperatures.
    Australia
    My install in amongst this thread. My thoughts only.
    Hope it helps.
    http://www.aulro.com/afvb/discovery-...nitor-but.html
    Dec 2011
    Me!bourne's West
    Thanks for the info guys.
    Looks like it's going in the middle of the manifold and not the dump pipe.
    R2
    Jan 2011
    Gippsland
    R2
    ...... just like this.
    Hi R2D2 I too have the VDO EGT Gauge, you can bend the probe buts it is bloody hard. i have the gauge mounted in a MudPod
    onebob
