Thread: TD5 Stall Test - Low Power
    Cambewarra, NSW
    Doing a Stall Test on a 2001 TD5 Auto in a vehicle that I am dismantling.
    The manual indicates that you should get 2600 to 2800 rev/min on a diesel.
    I'm getting 2100 rev/min maximum !!
    The manual says "A reading between 1300 and 2600 rev/min (Diesel)
    indicates reduced engine power."
    I've checked the MAF with the NANOCOM readings are OK, changed the MAF for a known good one - same result.
    There are no engine faults reported on the NANOCOM.
    It has oil in the injector harness which I have cleaned up and am flushing through with contact cleaner and metho. It revs quite smoothly and freely in neutral and sounds good
    The vehicle has only done 149000km, it has a Sequent II gas injection system, a TRS chipped ECU, an aftermarket (large) intercooler, the EGR has been removed and it has a 3" exhaust system.
    Any suggestions where I should look next?
    Update : Checked the Wastegate actuator (replaced with a known good one) and replaced the Ambient Air Pressure sensor with a known good one - still gives around 2100RPM. The wiring at the red plug on the ECH appears to have been modified - probably something to do with the Gas Injection system - will check that out next.
    Jul 2010
    Hunter Valley NSW
    Gary did you get another wreck to dismantle???
    Sounds like it could be the wastegate not opening.
    Glenn
    Cambewarra, NSW
    Hi Glenn, Yes it had a few good bits I was after. I'll pull it apart gradually and sell off what I don't need. If I can get it running properly I will keep the engine and sell the other engine with the new head from the car we pulled apart a few months back.
    The turbo was my next thought, it drove well up to about 30Km/hr in the limited space I had to test drive it.
    I'll check out the wastegate when the rain stops.
    Jul 2010
    Hunter Valley NSW
    EU -3 engine this time?
    Cambewarra, NSW
    EU-2, but I'll keep it and all its accessories for now, it even had a brand new alternator fitted. Might look for a TD5 Defender with a blown engine
    Cambewarra, NSW
    Eventually found the problem it was a neatly cut wire at the red plug on the Engine ECU. The wire in question goes to The Manifold Absolute Pressure (MAP) sensor on the inlet manifold. (Not to be confused with the MAF sensor.)
    The same sensor also does the inlet air temperature (IAT)
    If you still have the EGR fitted this sensor can get totally gummed up with tar.
    The manual states that Power is restricted if the MAP sensor fails. I had already changed the sensor but that didn't fix the problem - I now know why !
    Buderim, Sunshine Coast QLD
    Quote Originally Posted by gazk View Post
    So did Nanocom show no Manifold pressure?
    Regards Gordo
    Cambewarra, NSW
    Pretty sure it did - possibly the default value. I know the IAT was working. I'll recreate the problem tomorrow and check the readings - I will let you know the result.
    The workshop manual (18-1-13) states:
    The MAP/IAT sensor can fail the following ways or supply incorrect signal:
    Sensor open circuit.
    Short circuit to vehicle supply.
    Short circuit to vehicle earth.
    Contaminated sensor element.
    Damaged sensor element.
    Resistance in wiring harness.
    In the event of a MAP/IAT sensor signal failure any of the following symptoms may be observed:
    If the MAP sensor fails manifold pressure is set to a predetermined default value and the engine performance will be reduced.
    If the IAT fails the ECM will set air temperature to a fixed value. The MIL will not illuminate in a MAP/IAT sensor failure and the ECM will use a fixed default value from its memory.
    Update: with the MAP/IAT sensor open circuited the Nanocom shows the ECU's fixed value defaults as 100Kpa and 120C.
    Last edited by gazk; 9th June 2012 at 07:37 PM. Reason: information on default values
    May 2010
    brighton, brisbane
    Please excuse my ignorance, but what exactly is a stall test? [ probably something obvious, but I'm only on my first coffee] Bob
    I’m pretty sure the dinosaurs died out when they stopped gathering food and started having meetings to discuss gathering food
    A bookshop is one of the only pieces of evidence we have that people are still thinking
    Cambewarra, NSW
    D2 Automatic Transmission Test:
    From the workshop manual: Stall Testing
    1. Chock the wheels and fully apply the
    handbrake.
    2. Start the engine and run it until it reaches
    normal operating temperature.
    3. Apply the footbrake and select 'D'.
    4. Fully depress the accelerator pedal and note
    the tachometer reading. The figures should be
    as given below. Do not carry out stall test for
    longer than 10 seconds, and DO NOT repeat
    until 30 minutes have elapsed.
    l V8: 2200 to 2400 rev/min
    l Diesel: 2600 to 2800 rev/min
    5. A reading below 1300 rev/min indicates a
    torque converter fault, ie stator free-wheel.
    6. A reading between 1300 and 2200 rev/min (V8)
    or between 1300 and 2600 rev/min (Diesel)
    7. A reading above 2400 rev/min (V8) or above
    2800 rev/min (Diesel) indicates clutch slip.
    NOTE: The figures quoted above were
    measured at sea level with an ambient
    temperature of 20°C (68°F). At higher altitudes
    or higher ambient temperatures, these figures
    will be reduced.
