Thread: Question re transfer cases
    melbourne
    hey all long time no read been problem free for a long while yay
    that is untill the weekend, i lost my transfer case
    some how i managed to smash alot off teeth from 4 or 5 of the gears and also manged to snap a shaft the holds the gears
    how easy is it to remove the transfercase??? once front and rear props and hand brake drum are off,
    cheers guys
    matt
    Jul 2009
    Mid North Coast, NSW
    287.34 MB
    Not to hard just heavy. Rave says you use a mount on a jack to lower it down....
    May 2011
    Wyndham Vale. Vic.
    Hi, Done a few, one from underneath with jack, now do it from top useing engine crane, much easier once you drill the rivots out of the shift surround.
    melbourne
    Quote Originally Posted by disco 3 door View Post
    ok then, im looking at a floor jack in my drive way, not quiet a flash work shop lol
    rivets? please do explain
    cheer
    matt
    Aug 2009
    Sunbury Victoria
    Quote Originally Posted by matthewk View Post
    cheer
    matt
    He means to get access to the top of the box you need to drill the rivets around the plate that holds transfer and gear leaver after removing the centre console. Then you bring an engine crane in through the door and wrap a sling around the box and lower.
    The a picture of one I prepared earlier.
    Cheers, David.
    My Land Rover has made me a better Mechanic........
    D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack, Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
    melbourne
    Quote Originally Posted by Landover View Post
    you cant just lower it with a jack ? like the old nissan and toyota box?
    or do you really really need to get in at the top?
    Aug 2009
    Sunbury Victoria
    The problem is the shape of the transfer case. It will not sit flat on the jack. The Rave CD tells you how to make a frame to support it.
    Cheers, David.
