Thread: klonks steering box
    Aug 2011
    Albany WA
    klonks steering box
    Hi all
    Was after some help with klonks steering box. Its had a S2a box fitted but not very well, so want to do some improvements.
    The problem is that the arm on the box looks too long, is there a shorter one that can be fitted, as it is only about 1/2'' off the chassis and is very close to hitting the wiring harness and does hit the throttle linkage before getting full turns on the steering box. Dont know if this would happen when the steering is connected and the hubs hit the steering stops on the axel
    Have found that the worm and nut box has 2.5 turns lock to lock and he 2a one has 4.
    Also stiffening up the steering box mounting. The old one was made of a 1/4 plate stiffner on the drivers side of the bulkhead held on by 2 dozen 1/4 bolts and a piece of 1'' square tube from the steering box to the outer bulkhead upright. Ugly!
    Any photos and comments welcome
    Cheers Steve
    Ps Sorry couldnt put photos in as ive already put them in Klonks main page, cant repost.
    Quote Originally Posted by klonk View Post
    Either include a link to that page or post them up on a 3rd party listing site like Photobucket and copy the relevant img link to your post. Most forums use this same method.
    Aug 2010
    Western Australia
    Steve,
    Have a look on the Series one club forum www.lrsoc.com
    Use the search tool and a lot of information will come up on steering box conversion to the recirculating ball type.
    Going of what everyone else has done, they are using the Series 2a style mounts directly to the chassis instead of to the bulkhead as per the original. What horn button are you using now? The swamp man would have all the goodies you need brackets, not sure about which drop arm to use though?
    Andy
    Aug 2011
    Albany WA
    Thanks Garry had to get help, wasnt to hard.
    Please click on link
    A well used 80''called Klonk
    Andy Im using a S2 horn button in the wheel center and slip rings.
    Cheers Steve
    Aug 2011
    Albany WA
    Hi Guys
    Well here are some photos of what Ive ended up doing with the steering box mount. Not to keen with the bent drag link, done by someone else years ago, but it works. The bracket is out of a S2a, bent and cut down to allow the box to sit inline with the chassis and square with the bulkhead.
    The steering wheel is in the original position and angle and clears the lid for the petrol tank. Had to add the bracket on the outer side of the steering box to stop a small amount of flex that was present and is now rock solid when turned to full lock and forced.
    Cheers Steve
