Results 1 to 9 of 9
Thread: Exhaust Pipe Radiant Heat Problem?
    Mar 2009
    Near Geelong, Vic.
    I used the local exhaust shop to fabricate the connection of the Holden engine pipe to OE LR intermediate & muffler tailpipe system so as to get the exhaust to exit correctly ie over the O/S rear wheel.
    He has run the engine pipe a bit too close for my comfort under the N/S petrol tank:
    The clearance is 40mm.
    Should I be considering mounting a heat shield on the pipe? Eg via 2 upside down U-shaped exhaust clamps. Or am I being overly anal?
    Oct 2006
    canberra
    IDE be concerned about it getting hung up on on stuff in the bush and yeah I think it could cause an issue with h tank
    Irymple, Victoria, Australia
    You won't want that drain bung to leak!
    A bit close for comfort I think.
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    C00P Guest
    This is what I did...
    After these were taken I bent the edges down to extend the shielding of radiant heat.
    This is the normal exhaust system running under my auxiliary tank. Like you I was a little concerned that the radiant heat might cook up the fuel. The tank does get warmer than the other one, but some of that would be airflow from the radiator.
    Coop
    Mar 2009
    Near Geelong, Vic.
    Yep!
    That's exactly what I will do with identical clamps & strips of stainless steel.
    Mar 2009
    Near Geelong, Vic.
    All Done!
    *cue: a long drum-roll and a big clash of cymbals*
    *Waits for thunderous applause.....gets a single chirping cricket*
    That's 100mm wide light guage stainless steel with 2x 45deg folds for stiffening.
    C00P Guest
    How's that?
    Coop
    RIVERLAND, SOUTH AUSTRALIA
    Of course now the danger is that the exhaust clamp bolts will pierce the tank and then the fuel will flow over the guard onto the hot exhaust and....
    well you get my meaning Im sure...
    Mar 2009
    Near Geelong, Vic.
    Nah! I thought of that & trimmed 'em with my trusty angle grinder!
