Results 1 to 10 of 13
Thread: my 6yr old got hold of my keys
    gsaps Guest
    In an attempt at showing off, my 6 yr old got hold of my keys to unlock the doors, she obviously pushed a certain combination of buttons because now when i try to lock it, the hooter beeps and it doesn't lock, can anyone tell me how to return this to normal?
    thanks
    Grant
    Jul 2012
    Bendigo
    just to check, all the doors are properly closed?
    gsaps Guest
    thanks Michelle, yes, all doors and tailgate closed
    Aug 2010
    Sunbury, VIC
    What vehicle are we talking about here?
    gsaps Guest
    and the spare fob is still working fine
    gsaps Guest
    it's a 2010 Freelander 2
    Aug 2010
    Sunbury, VIC
    Maybe worth a try - Freelander key fob put new batts in still not working? - Yahoo! UK & Ireland Answers
    It is a response to a flat battery in the fob, but may work to reprogram it?
    gsaps Guest
    Thanks Bacicat, might have to get that done, I'll do some searching
    In the D2 if it's been unlocked and the bonnet opened & shut but the car not started or at leasted switched to ign then when you go to lock it it'll beep at you same as it will if a door is open or ajar.
    mikehzz Guest
    I put a new battery in mine. I was having trouble with the fob not working all the time and things beeping when they shouldn't. It turned out that one of the contacts on the old battery had sheared off. Eleven dollars for a battery, a bit of solder and some super glue had it working fine again.
