Thread: D3 fault since ARB Fitted Accessories
    Jul 2012
    Frankston
    Angry D3 fault since ARB Fitted Accessories
    G'day Guys and Gals, all excited yesterday as I was picking the D3 up after getting a snorkel, bullbar and compressor put on at ARB, only to become disappointed and now worried what they have done. Picked the car up to find the radio wasn't working and the terrain response unit flashing and not being able to adjust. Took it back and as it would happen it was all good, Got home and had to turn it back on to find the same issue, apparently they flattened the battery (left the lights on!) could it be this? Spoke to ULR and they suggested it may need an extensive charge of the battery, so over to you guys what are your thoughts
    Julian
    Just ordered an ARB bull bar for my D3 hope this doesn't happen to me. I have had the battery go flat on me due to a faulty alternator. On jump starting it then driving off I had every imaginable fault come up. After running the car for a while turned the car off and then restarted it and most faults cleared themselves. After driving for all that day stopping and starting the vehicle was back to normal. I would charge the battery up overnight then start it in the morning and fingers crossed it should be OK, if not I would be going back to where it was fitted
    Feb 2012
    Wollongong
    A flattened battery with low charge will cause those kinds of issues Julian. I have been told by my battery guy that they should be charged as driving is not sufficient if the battery has been seriously depleted. Recommend ctek battery charger. Good luck !
    Jul 2012
    Frankston
    Thanks guys hopefully a full charge is all it needs, I love this car but this is always in the back of my mind how smart they are. I would never go back to the Patrol as this is significantly better in every way but I didn't have to worry too much about it in this regard,(it was just about everything else I worried about lol) Just got to learn more about them from people on the forum so I know exactly what to do when something does happen
    Julian
    Feb 2012
    Wollongong
    If it is troublesome, follow the advice of the hitch hikers guide to the galaxy (don't panic). Then check your brake lights, if they're ok call the nrma or your mechanic hahahaha !
    But seriously, they're complicated but not that complicated and pretty much as reliable as any Japanese vehicle. I've learnt not to flinch when it does weird things, I just call it "character" !
    Feb 2009
    The low-battery-causing-faults thing is just another reason a dual battery setup should be high on your list - its worth it for the peace of mind alone...
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Jul 2012
    Frankston
    Quote Originally Posted by Stuart02 View Post
    I got a dual battery system installed a week or two ago
    If accessories have been left on, or doors continually open and shut without engine power, a dual-battery system won't help much (in terms of preventing faults - it will of course help with starting). It might prolong the inevitable for a short time, but these cars pull quite a few amps when they're "awake".
    Gordon
    Jul 2012
    Frankston
    Ok I decided since the battery was 6 years old rather than charge it up I will get a new battery, fitted it over the weekend and no joy still the same problem I had it booked in to Peninsula Rangie for the morning anyway and explained the situation and I've spoken to Damien since and he seems to have rectified it by recalibrating the suspension so over to you guys what would have caused it to s**t itself could arb have done something?
    By the way anyone down the southern suburbs of Melbourne you have to get Damien to look at your vehicle he is fantastic! How often do you get to say that about your mechanic!
    Julian
    Apr 2011
    Victoria
    +1 for Penisula Rangie
    My defender is there at the moment getting the head gasket done.
    Damien is always quick with a well balanced opinion.
