Will an engine have a shorter life if you run it j-u-s-t under the red line, with the occasional step over, - or on top of the Green, with the occasional visit near the red line???
If you have cheap or middle-of-the-road panels, then MAX output will only occur if they're at right angles to the sun's angle and when the sun is happiest...
If you have 'better' panels, they could go over their rated output under good - not perfect- conditions, as mine occasionally do...
Heat kills any electronic gizmo, and running close to red-line is going to shorten the Mean Time Before Failure.
Then there's the method the manufacturer uses to rate his inverters...
