Results 1 to 4 of 4
Thread: SII/SIIa/SIII hardtop bolts on SI hard top?
    East-South-East Girt-By-Sea
    1.20 MB
    Hi people
    I don't have any 80" gal cappings here in Sydney and need to find 4 bolts to secure an 80" hard top to an 80" for the journey from Glenreagh to SEQ. I was hoping to use the bolts off a SII/SIIa/SIII which I should have enough here.
    Does anyone know if the later ones will be long enough to do the job on an 80"?
    Diana
    Nov 2011
    Hi Diana
    I don't know the lengths but you could go to a bolt shop and buy a metre of threaded hi tensile bar, some washers and nuts. Wouldn't cost much and the bar chopped into 4 would be plenty long enough.
    Cheers Duncan
    1.20 MB
    Thanks for that suggestion Duncan,
    I was hoping that someone with an 80" would be able to measure and even pop one of the special bolts for the SII/SIII into the hole on the 80" capping.
    Diana
    Feb 2009
    Prob a bit late but yes the longer hard top bolts on S2 and 3's fit the 80" landies cappings, I fitted a set to one last year, just need the larger diamater washer on top to hold the hard top on.
    Wardy
