Results 1 to 10 of 14
Thread: 300tdi timing tools
    Aug 2008
    Kuala Lumpur, Malaysia
    300tdi timing tools
    G'Day
    just made a swanky locking tool for the pulley http://www.aulro.com/afvb/1765347-post108.html with a terrible drawing here http://www.aulro.com/afvb/attachment...y-picture1.jpg but it works
    Anyone got dimensions for the 2 pins?
    I know I can use a drillbit, but as its cheap to machine up here I am making up the full set plus the puller
    On the puller subject what M size or bolt diameter is the main pulley bolt? I am outstation so cant measure it and was going to get it made whilst I am away ie remote Land Rover tinkering
    NSW far north coast
    I made the flywheel locking tool by drilling and tapping a 1/4" BSP plug to 6mm and turned the end of a 6mm SHCS to 5mm to fit the slot in the flywheel.
    I think there's a piccy on here somewhere, I'll try and find it.
    Aug 2008
    Cheers if you can as I can email it up to my machine shop and get them to make them up
    Gives me something to do as nothing to do at or around this hotel.
    NSW far north coast
    Found one.
    I used an SAE flare to BSP adapter that I had on the shelf and the blanking plug is beneath.
    Aug 2008
    Quote Originally Posted by rick130 View Post
    Found one.
    So this is the fuel injection pump one?
    What size BSP thread and what diameter pin?
    I have to sketch and fax to the machine shop
    NSW far north coast
    Flywheel locking pin.
    As I said above, 1/4" BSPT into the flywheel housing, and the slot in the flywheel is 5mm wide so I just used bits I had to hand, including the 6mm SHCS with the end turned down to 5mm to fit the slot.
    Aug 2008
    ahh I got it... I was misreading the bsp as a thread size not a plug size.....
    that should be easy enough
    NSW far north coast
    Quote Originally Posted by fesm_ndt View Post
    It is a thread size, it's 1/4" BSP taper, just one of those anachronisms where most everything else is metric except the bolts and nuts on the prop shaft flanges which are 3/8 UNF.
    NSW far north coast
    Except as I keep telling you Dave, it's a BSPT thread, not metric, it's just that 1.5mm pitch is close.......
