Results 1 to 10 of 13
Thread: What is it? Random Dash Electronics - 93 200tdi defender 110
    UBZ Guest
    I had my dash apart to move some guages and install a tach and came across this covered in foam and wired into the dash loom just behind the guages .
    Anyone know what it does ? I've looked through the factory wiring diagrams and can't identify it .
    I thought my 110 was essentially electronics free. Is this a factory item or aftermarket meaning I can rip it out ??
    Jul 2011
    Yarrawonga, Vic
    does it have a serial number or part number etched into the pcb on the solder side. can you take a photo of the solder side showing the tracks, it will be easier to identify.
    Somewhere else, QLD
    Highly possible that the previous owner installed it as a power supply regulator for the dash gauges. ie drops 12v down to 10 or 5 volts for the fuel, oil, temp etc.
    That or something for the hazards. See where it connects to loom and see what wires are used.
    85 county is offline AULRO Holiday Reward Points Winner!
    Sep 2010
    adelaide
    what are the wire colours
    black is earth, white will be a power ( white red trace is dash lights) green black trace i think is fule gage and green with blue is temp, i think. but i can check when i get home.
    Jan 2010
    tom price the pilbra, west aust
    its obvious your under survelliance from the goverment
    Aussie Expat in NZ
    Quote Originally Posted by langy View Post
    I can't see a normal voltage regulator that would be used (like a 7805) so I don't think it would be that. The 8pin IC is too small and would need a heatsink.
    What is written on the 8 pin IC? 555? If so, it could be a musical horn circuit or hazard lights.
    Aussie Expat in NZ
    It might be a frequency to voltage converter for a tacho like a LM2907.
    Jan 2009
    On the road around Australia
    Looks like a 2904 op-amp, hard to tell in that photo. Any chance of a close-up of the chip??
    Mar 2007
    Canada
    What is it connected to??? That should tell you a lot...
    Mar 2007
    Canada
    If that is a white/slate wire, it should be the wire to the alternator for the tach signal. Might be some sort of signal conditioner. Nothing is in the factory wiring schematics.
    edit: Hang on. W/S can also be the low fuel warning. Probably a unit to determine when the level is low. Green/Black is the fuel level signal and W/S goes to the light.
