Results 1 to 10 of 12
Thread: What is a Leading Arm?
    Nov 2011
    QLD
    Had my 1995 P38 HSE in at a suspension workshop today they told me that I need to replace the Leading Arm(s) as the bushes are worn. But for the life of me can't find any part listings for a leading arm. Is there another name for this? Cheers.
    They could've referring to the radius arms. Would be surprised if you have to replace the arms just the bushes would make sense. There is a need for pressing out old and in new for the barrel style ones if you stick with std. If you convert to PU (plastic) ones you can do away with pressing moving forward.
    There is a guy on ebay sells super pro brand (good quality) for very reasonable prices. Will see if I can find some photo's and links for you tonight.
    Hoo-Roo,
    Dave.
    Coogee, South of Fremantle, WA
    I agree, Radius arms. I think similar are called leading arms on Patrols etc which I am sure your mechanic will be more used to. Go with new bushes as advised
    Attached Files Attached Files
    Avoca Beach
    A trailing arm is where the chassis pivot point of a suspension arm is nearer to the front of the car than the arm mount on the axle. EG 38A REAR suspension.
    A leading arm is where the chassis mount is behind the axle mounting.eg the FRONT suspension of a 38A.
    This description applies to all vehicles AFAIK.
    Regards Philip A
    d@rk51d3 Guest
    Regards Philip A
    I was about to suggest "the opposite of a trailing arm", but didn't think it would be that simple.
    Nov 2011
    QLD
    Quote Originally Posted by DT-P38 View Post
    Thanks mate, your right its just the bushes. I've had a couple of quotes to have these replaced ( Pedders $250 plus parts & my RR specialist $638 inc parts). This seems a lot to me given its just bushes.
    May 2008
    Lismore, NSW
    Find yourself a helpful engineering workshop or someone with a press. Remove the arms and get them to press the old bushes out and new ones in. shouldn't cost anywhere near that. I got mine done for the cost of the bushes.
    Warren
    Currently Landroverless - Still interested
    Formerly: 2003 D2a Update TD5 Auto. Platinum edition. ARB Bar, 36" LED light bar, cargo barrier, dual batteries.
    Jan 2012
    Bendigo
    I'm a but sus that your being told your radius arms need replacing, they're not easily damaged.
    Are you being taken for a ride?
    Nov 2011
    QLD
    Quote Originally Posted by benji View Post
    Its just the bushes mate, my mistake.
    Quote Originally Posted by gt0336 View Post
    The factory bushes are cheap and the PU ones aren't too bad. It's labour that would eat up most if the charges. Still should only be a couple of hours work in the right workshop though.
    I would estimate roughly $300 maximum for good PU fitted and less for genuine/OME. Say $250. Buy genuine yourself off ebay UK or SuperPro off ebay AUS and go to Pedders.
    Hoo-Roo,
    Dave.
