Results 1 to 6 of 6
Thread: Retractable Seatbelts on a 2A Tray
    Mar 2009
    Near Geelong, Vic.
    Fitting to a 2A was pretty straightforward
    The reel mounts on the little shelf where the window panel sits on the rear panel. Both reel & top buckle mount thru the factory re-inforcing gussets
    The lowest mount is the factory unit at the base of the seat box
    The centre mounts were a bit of an issue as the aluminium wall is so feeble. I used VERY big re-inforcing plates
    NOW for someone to do a sympathetic RWC!
    Mar 2009
    Near Geelong, Vic.
    Missed a photo!
    Centre mounts:
    stevep Guest
    looks good - do you have to go thru a rego inspection?
    also where did you get the belts?
    I have to do the same for mine but am about 2 years behind you
    regards
    Steve
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    I would be inclined to simply use the Series 3 bits. Note that on the trayback the inner mounts should have straps diagonally back to the chassis. As the retractable belts were post 2a, you may need engineering approval in some states despite their being standard Landrover parts and the 2a and 3 being structurally identical in this area.
    Mar 2009
    Near Geelong, Vic.
    John I intended to make straps/yokes to go back to chassis for the centre mounts but I got lazy & I'm guessing/hoping that 2x150mm square pieces of 3mm gal plate will appease the tester.
    Seat belts from:
    SeatSafe Seatbelts
    But they are Hemco brand and are made in Ballarat. About $300 all up for the set.
    Aug 2012
    Adelaide
    $300 for the set! dam that is expensive! I got mine from Paddock spares in UK, they were cheap as.
    Although I did get other stuff with them so that cut the frieght cost down, if you know what I mean....
