Results 1 to 10 of 15
Thread: Handbrake adjustment?
    Oct 2011
    Burra NSW
    Guys, does anyone know how to adjust the handbrake on an 04 rangie?
    Aug 2010
    Sunbury, VIC
    I did mine as per the Manual, which involves adjusting the shoes at the back, but it did sod all, and it is still ****. I'm thinking the shoes are glazed up and I need to pull them out to clean them up or replace them, but if I there is an easier solution, I'm all ears.
    Cheers - Gav
    Dec 2011
    Toowoomba
    As per manual.
    Attached Files Attached Files
    Dec 2011
    Toowoomba
    Forgot to mention; the handbrake shoes interchange with same era Touareg, BMW X5
    Porsche Cayenne, Audi Q7.
    Jan 2012
    Sunshine Coast, Australia
    This adjustment didn't work for me either (100,000km MY05)
    So took it into service and they pulled apart cleaned and adjusted - Zero difference. Still zero handbrake.
    Next service they ordered new cable and fitted it. Zero difference. Still no handbrake.
    Now they beleive its the ratchet in the handle itself and it goes in next Friday to try that.
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by donrover0 View Post
    As per manual.
    Yeah, that's what I did with no result at all.
    I hope CBH25 gets to the bottom of it...
    Dec 2011
    Toowoomba
    handbrake adjustment
    So have any you guys with hansbrake problem actually taken the disc/drum off, then observed what happens when handbrake off and on? If the shoes moved, then seems just adjustment. If shoes don't move , then either cable or handbrake lever problem.
    Easy to narrow down where.
    Aug 2010
    Sunbury, VIC
    Waiting to see how CBH25 goes with a new handbrake lever. He has done everything else... Mine is more than an adjustment issue. The cable pulls the shoes on and releases ok, it just doesn't seem to put enough pressure on the shoes to do anything worthwhile. It is low on my list, but I was going to shove some new shoes and rotors on and see what happened.
    Mar 2007
    I have had similar problems, if the shoes arn't worn they are usally glazed. Cleaning the shoes and drum with emery paper usally will restore the lost friction surfaces, and follow the adjustment as reported above,BUT just find the right amount of clicks on the adjustment cog for your car. Some will be "8" alot can be +- 2 clicks.
    From Disco3 UK Site, it's a very comprehensive adjustment guide on the D3 brakes, BUT is a excellent guide as the systems are quite similar. Well worth putting in your maintenance / repair folder.
    Laurie
    http://www.disco3.co.uk/gallery/albu...le_V1.4sml.pdf
    Jan 2012
    Gents mine is going in next Friday, so we have another 8 days to hear my results.
    Ill let you know though.
