Results 1 to 9 of 9
Thread: Jam Tin Brake Reservoir
    Mar 2009
    Near Geelong, Vic.
    Damn!
    My jam tin showed no signs of leaking during the resto but has started after a couple of days on the road.
    A slow drip from the bottom.
    I know they are not available locally so I'm reluctant to rip into it lest it's unrepairable/split & I can't do anything with it. I can keep topping it up every 2-3 days.
    Craddock's have these:
    504105 - REPLACMENT RESERVOIR KIT SERIES 2 BRAKE AND CLUTCH - Series 2 Parts
    Comments?
    Dec 2009
    Queensland (though occasionally elsewhere)
    Well, as long as you're not too worried about changing from the original jam tin, I'm sure these would be fine. Nice tidy looking setup, actually. Alternately, you could change the clutch master cylinder to the later type with inbuilt reservoir and use the plastic Series III reservoir for the brakes.
    Narre Warren South
    Try Pegasus Parts
    504135 - Clutch and Brake Fluid Reservoir Tank, Early 1958 only
    http://www.pegasusparts.co.uk/oursho...voir-Tank.html
    Last purchase they were very slow, only take PayPal (no credit card facility).
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2009
    Near Geelong, Vic.
    I've tracked it down to the union that bolts to the bottom of the tin. It can be tightened but it just turns so there must be a bolt head INSIDE the reservoir that is rotating.
    I can get a clean tube spanner down there.
    Does anyone know what size it is? The outside nut is an 11/16ths UNF.
    Sep 2011
    Adelaide
    Not sure of the size but it may be worth removing the reservoir now to give the inside a good clean and also to check the sealing washers on the leaking union
    Mar 2009
    Near Geelong, Vic.
    I borrowed a set of tube spanners.
    It's a 3/4 AF.
    Half a turn nipped it up & fixed the problem!
    Jun 2008
    Morpeth NSW
    I got mine for 35 pounds from lrseries.com to replace a jam tin.
    The bracket had to be filed out to line up with the pedal tower, which was pretty annoying, but otherwise fitted up fine. I like the fact I can keep an eye on my levels without opening up the tin and peering in. I'll upload some photos later if you want?
    Sam
    schuy1 Guest
    Quote Originally Posted by geodon View Post
    It's a 3/4 AF.
    From memory there is a flat rubber washer that seals the clutch fkuid tube from the brake fluid container outer. and it does perish so you may find it will start leaking again. Not hard to replace now you know the size I found with old 1s any disturbance like removing the pipes would start it off.
    Cheers Scott
    smurf village
    are these reservoirs the same as a s1 but just with the extra hole?
