Results 1 to 3 of 3
Thread: Leaf Spring Bushes - Loose Bushes
    Apr 2011
    Wandong,Victoria,Australia
    Hi All,
    I am working on my 1960 Series 2 - SWB.
    When I removed my rear Leaf Springs, the bushes in the rear of both spring eyes simply fell out. The spring eye doesn't look damaged. I purchased some replacement bushes - and they too don't sit tight in the spring eye.
    All of the other bushes (the front of the rear leaf springs) and both ends on the front leafs - are very tight. On another project I had to drill the rubber out so that I could remove perished bushes - so I know how tight they can be!
    Do I have to resolve this issue? (I assume that the bushes could expand over time with heat?) But I also assume that it the bushes are too loose, it could cause movement, which probably isn't good either.
    How do I resolve this issue?
    As always any help is greatly appreciated.
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    You should resolve it. The eye should be easily crimped shut the necessary small amount, possibly in a large vice or a press. An alternative, requiring the donning of a striped apron, is to shim the bush so that it becomes a press fit - jam tin works well, although you may have to experiment to work out how much of a full circumference is needed. Although not an approved method, I have seen it work quite well in spring eyes; don't use it in solid bits such as the chassis bushes or on coil sprung arms.
    Id suggest getting the springs reset.
