Results 1 to 9 of 9
Thread: locking centre differential 2000
    Jan 2012
    Manly, NSW
    I just read this in an article about the D2.....
    "The locking centre differential was still fitted until early 2001, although the linkage to operate it was not attached, as Land Rover believed that the traction control and newly-developed Hill Descent Control would render it redundant. The actual locking mechanism was removed in early 2001"
    How do I know if my May 2000 Built D2 has the lock? It was registered 2001, but built May 2000.
    Can I now add the linkage if so how?
    Jan 2012
    Manly, NSW
    http://www.discovery2.co.uk/diff_lock.html
    I may have answered my own question....
    Any anyone done this?
    May 2003
    On The Road
    only about a million people on here Rob
    lots of solutions, including that one.
    there's even something in The Good Oil,,
    who'd a thunk it??
    Search (bottom of page) is your friend
    Feb 2011
    Brunswick, Victoria
    You obviously haven't searched the forum
    http://www.aulro.com/afvb/1681251-post6.html
    MY2002 D2's don't have the CDL internals. The last few months of the MY2001 also missed out on the internals. The model years run from august/september of the previous calendar year. MY2002 runs from roughly August 2001 through to August 2002. MY2001 vehicles built from around April/May onwards don't usually have the CDL internals.
    There is an approximate VIN range for the cut off in this sticky under the MY2001 entry:
    http://www.aulro.com/afvb/discovery-...ates-vins.html
    The date range is based on forum members reports of fitted/not fitted. The period from mid April to 24 May 2001 has no reports and the change between CDL equipped and no CDL occurred somewhere between those two dates. If you can PM me your VIN it should help refine the change over dates once you determine if the cdl internals are fitted.
    You'll need to physically check for the shaft on the top of the front of the transfer case for the CDL shaft or check the case serial number. The presence of the shaft is probably the most reliable means of checking.
    As for CDL's here are a couple of recent ones to get you started:
    http://www.aulro.com/afvb/discovery-...diff-lock.html
    http://www.aulro.com/afvb/discovery-2/134040-cdl.html
    Paul
    Jan 2012
    Manly, NSW
    [QUOTE=OffTrack;1808842]You obviously haven't searched the forum
    I search by Proxy... Cheers Paul ;-)
    Jan 2011
    Gippsland
    who'd a thunk it??
    Bloody Hell! I never noticed that lower search button - the results it returns are very comprehensive. Until now i've struggled with the search function in the top header..... thanks Pedro
    Sep 2013
    Chambers Flat
    Looking at a D2, using the VIN, I may have the CDL
    SALLTGM931A is the startt of the VIN, could be a possibility of having the CDL from the factory, but no lever to activate, couldn't have a real good look under it to see though.
    Thanks for all of the great advise that this site can give.
    Bairnsdale enjoying the rural view no rooftops to see here
    Quote Originally Posted by Robgw View Post
    I fitted a D2A one in mine on the weekend found the easiest way was to remove the console t bar and transfer case lever drilled out the rivets in the shifter base plate and easy access to fit cdl mechanism
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    Jul 2007
    Two Rocks, W.A.
    Quote Originally Posted by Outback 1 View Post
    My Aug/Sep 2001 had the internals, so you can never tell. Shortly after buying it I assumed I was up for the whole retro fit...until the CDL warning light switch failed and the light started flickering on the dash. This prompted investigation and lo & behold there was the nut on top of the transfer case...
    As Outback 1 described, this was the route I took. I used the Ashcroft shifter kit and a modified D1 output housing.
    Mike
    '00 D2 Td5 'Alice'
    '03 V6 Freelander 'Phoebe'
    '04 Td4 Freelander 'Harry'
