Results 1 to 10 of 15
Thread: 3x Optima D34 in the battery bay?
    Aussie Expat in NZ
    Has anyone tried to fit 3 D34 Optimas into their County battery bay? Measurement seems to fit, but I'd like to be sure before sinking the money on an extra one...
    Canberra, Australia
    If it would help you with the fitting etc I have a D34 case, so no weight etc. Call or pm if you want to borrow the case.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Feb 2005
    Pretty sure somebody has.....maybe do a search
    Jan 2009
    On the road around Australia
    camel_landy mentioned doing this quite a while back, if memory serves.... lets see if the search tool works...
    [edit] Pic posted by camel_landy in an earlier thread:
    I have 2 optima blue tops + the standard battery in my Puma so they certainly fit in the later model
    Rob
    Nanny state UK...
    Ah ha!
    I see Mike has already found my pic.
    The red-top is the main SLI with everything else hanging off the pair of yellows (wired in parallel). I've got one of those solid-state split chargers between the red & yellows.
    FWIW - Now that I've tried them, I wouldn't bother with any of those fancy batteries again. Just stick to the regular lead-acid types.
    M
    Aussie Expat in NZ
    Thanks everyone. 3 fit, however with the early 110's the battery box is a slightly different shape, you have to have the 2 side by side at the front and the single at the back, otherwise the terminal posts stick up too far and would short against the cover.
    Special thanks to Michael for his ghost batteries - They make it so much easier.
    n plus one Guest
    Quote Originally Posted by camel_landy View Post
    Ah ha!
    M
    Care to expand on this comment?
    Scarborough, QLD
    Nanny state UK...
    Quote Originally Posted by n plus one View Post
    If you want all the details, do a search back to Jun/Jul '05... Essentially the pair of yellows I had in that photo died when they were only a couple of months old and I had absolutely no support from Optima. They didn't want to know.
    So I fitted a pair of Oddesseys...
    Frankly, I never found any benefit and have found the Lead-acid to be far more reliable.
    M
