Results 1 to 6 of 6
Thread: 1964 Series 2A
    whitespace@live.com.au Guest
    1964 Series 2A
    Hi landy people
    I have just acquired an ex army 1964 Series 2A
    its in good condition but requires new seals and bushes to do to make it roadworthy. I have tracked its chassis number to ARN 112-886
    I would liove to find out which unit the vehicle belonged to any other info about its service history.
    Any advice greatly appreciated.
    Regards Greg
    East-South-East Girt-By-Sea
    1.20 MB
    Hi Greg
    Service and unit history for Australian army vehicles are relatively hard to find because that information is generally not available to the public. If you found the ARN, you have likely been to REMLR and they will have the most information and members to assist.
    Most people find out their vehicle's unit history by archaeology on the vehicle itself. Rubbing back the paintwork to see if any formation signs and christmas trees were painted on.
    If the vehicle is not an ambulance or fire engine and has a full base overhaul plate (usually a plain aluminium plate stamped with a workshop and date around 1972 - 1973) there is a good possibility the vehicle went to Vietnam. Then you can search the photo archives on RELMR etc looking for your vehicle.
    You can also do some research at the Aust War Memorial.
    Diana
    Oct 2007
    wetherill park
    Hi welcome to the forum.
    Finding its history and units can be a little difficult as there are no public records as such but if you can find any unit markings on doors somtimes under layers of green paint some one can usually tell you something and pics will help '
    Edit: diana beat me to it
    Thanks Diana
    I cant find a work shop plate. it has had a paint job in civi life. Where would it be located?
    Regards Greg
    LandroverScott Guest
    Quote Originally Posted by whitespace@live.com.au View Post
    Thanks Diana
    Regards Greg
    Try inside the engine bay, on bulk head either centre top or passenger side. roughly 2 1/2 inches long x 1" high
    Jan 2013
    Central Australia
    Welcome to the board, and well done on your vehicle.
    I wish you luck in your search for the car's history. The suggestions here should keep you busy for a while I have a civilian 2a, but I took great pride in finding out as much of it's history as possible. Yours should prove to be an interesting search
