Thread: Engine mount replacement
    So the RHS mount gave way going up a decent sand dune on the weekend. The dent in my bonnet is making me more cross!
    How hard are they to replace? Easy to buy too?
    It's a 4.6 block, assuming its the same mount as the 4.0 original?
    Disco 2 V8 Part No KKB102450... expect to pay between abt $42 after market or $100+ for genuine OEM equivalent. The P38 4.6 part No: ANR 2620 $47 after market and about $73 for OEM. Pull off the busted one and see if there's a part number stamped into it. RAVE is your friend for deatils re. changing engine mounts
    Dalby
    Google QT engine mounts and you will never need to replace one again.
    Aug 2012
    Arkansas, USA
    The 4.0 and 4.6 disco uses the same mounts. (The blocks are identical.)
    I agree with the qt mount suggestion, except that they are expensive. I've replaced the monts on my 4.6 once. I guess if I have to do it again, I might spring for the more expensive mounts.
    Mar 2010
    After market they are $17.55.
    Genuine are $64.19.
    They only weigh ~1kg so postage should be pretty good.
    Britcar (UK) Ltd > Your Search Results
    Andrew
