Thread: diff backlash
    diff backlash
    I am starting to get stuck into my rebuild of an 86" with a series 2 2.25 engine.
    It was bought as a basket case.
    The diffs both have a lot of play - backlash. I can't seem to find much in the WSM (usefully says to pop them off to Rovers for a rebuild!).
    How much is OK?
    What is involved in tightening them up?
    Russ
    smurf village
    do you have a press?
    smurf village
    here is my diff work it may be of some use to you
    starting series 1 restoration
    JDNSW's Avatar
    Most of the backlash is probably from end play in the differential gears. This is very unlikely to give any problems. However, if there is any side or end play in the pinion or carrier bearings, then attention is needed. Pulling the diff out of the axle housing and checking the play is be pretty simple.
    australia
    Quote Originally Posted by rfurzer View Post
    How much is OK?
    Russ
    hi ring me regards rear diffs jim o428732001
    Narrogin WA
    You can't have a Rover manual then, because the procedure is very detailed in the genuine workshop manual. Available from most online Land Rover parts dealers,
    Cheers Charlie
    Narre Warren South
    How much is OK?
    Russ
    Series III manuals are available online, rebuilding a Rover diff is covered in detail.
    Just search 'Land Rover series 3 manual download free'.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
