Thread: Help to ID Dual Battery unit
    Aug 2011
    Hunter Valley NSW
    G'day,
    Can anyone shed some light on the manufacturer of this dual battery system, it came with an ex bash service car I bought and I'm interested in using for my 130.
    Its a simple system with a 3 wire hook up, maybe too simple for the electronics associated with the TD5.
    Jas
    Gold Coast Hinterland
    It appears to be a relay change over for the batteries.I would check that one set of contact are closed when switching at all times otherwise the alternator wont be excited and the rest of the electronics will have a problem
    Canberra, Australia
    Looking at the orange wires, marked as main and auxiliary, I'd guess it is an old Piranha system. The use of standard auto type relays inside also points to Piranha ... quite unsophisticated system.
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Queensland
    Going on both the cables and the potting, I’d say it was an early piranha too.
    Aug 2011
    Hunter Valley NSW
    Thanks for the replies guys, everything said makes sense....a cheap VSR with a pretty low amp rating.
    Thanks,
    Jas
