Results 1 to 10 of 19
Thread: Interior Lights/Open Door alarm
    Mar 2012
    Sunbury
    Interior Lights
    I am seeking advice regarding the interior lights. Tonight, no lights when I
    unlocked and opened door.
    Relocked & unlocked a number of times, opening door on each occassion, same result - no automatic switching on off interior light.
    Lights turn on with switch, headlights illuminate when lock button held down, so appears BCU functioning.
    Suggestions?
    Aug 2009
    Sunbury Victoria
    If you have the interior light left on and don't lock the doors they go into some sort of sleep mode. It clears when you start the car with the key. I spent ages looking over mine to try and work out why it was not working then after a drive all good.
    Cheers, David.
    My Land Rover has made me a better Mechanic........
    D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack, Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
    Jan 2011
    Gippsland
    yep... ditto Landover
    if you leave a door/s open for an extended time the BCU will kill the lights after 8 minutes to prevent discharge of the battery. Close doors and start vehicle to reset.
    onebob
    Occasionally mine will throw up a transmission fault when this happens
    The M & S warning lights illuminate. They won't go off with a restart, and require the Hawkeye to clear them. The fault is for a "CAN timeout - historical",
    Usually the aforementioned start-up sorts it out.
    and people wonder why some don't trust cars with electrickery.
    Mar 2012
    Sunbury
    Interior Lights Originally Posted 29/12/2012
    Suggestions?
    Thanks for the suggestions the last time I posted this query. All previous suggestions/recommendations acted upon without success.
    I have looked at all fuses, connections etc., disconnected & reconnected battery with a 15 min interval, however still no interior light upon opening door. In checking I have also noted that the Door Open Alarm is no longer sounding.
    Still seeking to rectify problem.
    All (reasonable) suggestions will be considered and acted upon & effectiveness reported in this forum.
    May 2003
    On The Road
    so the interior lights work when the actual light switch is moved?
    (sorry , good excuse for a bump if nothing else)
    Jul 2010
    Hunter Valley NSW
    open drivers door
    Put key in ignition
    Turn ignition on then off again
    Interior lights should turn on.
    Mar 2012
    Sunbury
    Yes, lights operate when the switch is moved to the manual on position
    Mar 2012
    Sunbury
    Quote Originally Posted by northiam View Post
    open drivers door
    Put key in ignition
    Tried your recommendation - no change
    Coogee NSW
    D2 RESET
    1) With key in the ignition, motor and ignition in the off postion
    2) open drivers door
    3) remove key wait 10sec
    4) insert key
    5) close drivers door
    6) start car
    Found this. Done it?
