Results 1 to 6 of 6
Thread: Rear door locking
    Dec 2010
    Queanbeyan
    Rear door locking
    Hi people,
    I have a 2011 Defender 110 wagon. In recent days the rear door has ceased to unlock with the remote and requires unlocking with the key. All doors lock with the remote as normal. Any ideas. Still under warranty.
    Thanks,
    Iglooist.
    Happened to mine mate, 2010 model. Just rip the door trim off, pull it apart and lube it up and good to go again.
    Rob
    Jul 2012
    midwest W.A
    Mine as well, 2007 110. I found the thumb lever for the inside was catching on the door skin. Skimmed a bit off the plastic door skin, lubed the mechinism and haven't had a prob since.
    Peters1 Guest
    My fix for lock
    I had a problem like this and use this kit to fix.
    Landrover Defender Safari Door Lock Repair Spring Kit | eBay
    The little spring inside had malfunctioned. works a charm now
    Peter
    Sep 2006
    Northern Beaches
    Thanks Peters1, and sorry IGL002 for the thread hijack, but I have been using duct tape for years for that problem.
    Jeff
    Jan 2012
    Re: Rear door locking
    Hi,
    Had the same problem. Took it to the dealers which cleaned and checked locking mechanism. Worked for a couple days then same thing. They then replaced whole mechanism and haven't had a issue since. This is a MY12
