Results 1 to 3 of 3
Thread: A powerpoint problem
    Sussex Inlet. N.S.W.
    We just had a new data projector installed and we are struggling with powerpoint presentations. On boot up the projector shows a high res picture on wall. As soon as a powerpoint file is loaded the picture shrinks to half size. All setting have been tried and despite the projector being told what res the powerpoint picture should be, it over-rides with this half sized picture . Can anyone shed some light on this problem? As a continuance, is it possible to save pp files with different resolutions ie file produced on different computer, etc Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    we get this problem at work occasionally when trying to run the main computer screen and the projector (normally on visiting laptops that get plugged in)
    if the computer trying to use the projector sees a projector and doesnt have a driver for it or is configured to use the projector as a duplicate or secondary monitor then the projector is being told to display whatever the computers primary output is configured to.
    if the projector is trying to display in say 1025x780 and is only getting a 640x480 you wind up with an about half size picuture on the projected display. This is a problem with the way that powerpoint uses secondary displays for running shows in full screen if the 2 screens are different sizes and havent been successfully permanently setup in the windows display configuration .
    the best workaround I've found for this problem is just to set the projector as the primary display, the main screen as the secondary screen then set power point to use the second display to display the presenters note and use the main display for the full screen presentation.
    If that doesnt work disable presenters notes and just use the projector as the main display.
    St Helena,Melbourne
    4.28 MB
    I like the Clipsal or HPM variants myself .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
