Results 1 to 9 of 9
Thread: Discovery 2 wheel stud thread type?
    Feb 2011
    Hobart, Tasmania, Australia
    Question Discovery 2 wheel stud thread type?
    Anyone able to confirm the thread of the wheel studs on a D2? Looks like M14 x 1.5?
    Yep...
    Avoca Beach
    That's a good link.
    Should be in every post!LOL
    Regards Philip A
    Feb 2011
    I read through numerous threads hence why I suspected that they were M14 x 1.5. However, some of the UK sites had threads debating on whether they were M16 or M14, which is why I made this thread to check.
    I can confirm that my new M14 x 1.5 wheel nuts thread perfectly.
    Dec 2011
    sydney - pining for the western desert
    Quote Originally Posted by twr7cx View Post
    However, some of the UK sites had threads debating on whether they were M16 or M14.
    M16 is the D1/Defender/RRC wheel stud
    Disco IIs, inc. my 2003 Disco IIa, have 16 mm studs.
    Disco 3 & RRS have 14 mm studs &
    Classic RR & Disco 1 have 14 mm studs.
    This is in line with the following info on 4x4 wheel nuts Land Rover, Range Rover Sport by PRI Racing authorised distributor
    Wheel nuts for Range Rover, Range Rover Sport, Discovery, Defender. Take careful note of the listing below along with the thread size and seat type.
    DRR - Range Rover 1993-2002, Discovery 1993-2004 Note this is M16x1.5 version - Shank diameter 28.5mm, HEX 27mm
    DRR2 - Range Rover up to 1992, Discovery 1993-1998 Note this is M14x1.5 version, Defender 90-110 - Shank diameter 28.5mm, HEX 27mm
    DRR1 - Range Rover 2002-2005 - M14x1.5 - Shank diameter 20mm, HEX 22mm
    DRR3 - Range Rover (inc. Sport) 2006>, Discovery 3 - M14x1.5 - Shank diameter 22.5mm, HEX 22mm
    South Sydney
    Quote Originally Posted by kgmcc View Post
    NO THEY DON'T
    Thats is all rubbish
    Seeing's I'm on AULRO not pirate i won't go all noob bashing on you.
    Anything LR with a 5x120 PCD has 14x1.5mm wheel studs (dunno about freelanders, not even sure what PCD they have).
    Will
    As per Jnr...
    D1 and RRC 5 on 165mm 16mm
    D2, P38, D3, D4 & RRS are 5 on 120 pcd and 14mm studs
