Thread: Window Woes
    May 2009
    Tatura, Vic
    Window Woes
    My passenger window went down and won't go up. Even though it is at the bottom it still wants to go down further. I did a search and could only find problems with spot welds breaking and nylon wheels also breaking. Both of these are ok.
    What has happened is the half moon gear has come out of the motor gear.
    My question is this. What or how is the glass limited on the down (and up for that matter) stroke? When it gets to the bottom what stops the motor?
    I re-engaged the gear and the window went up ok. When I lowered it, same thing. It just kept going until the half moon gear came out, and then it is making horrible noises if I hold the switch.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    From memory nothing.
    Time for a new regulator I'd say. Had the same happen on my D2a and twice on the D1. All use the same units. Check the teeth for wear and also the rollers in the slide. I couldn't have repaired mine being where I live but you should possibly be able to.
    Bairnsdale enjoying the rural view no rooftops to see here
    power window
    just replaced the motor in mine would not go up unless you pulled it by hand then motor then hand .rollers and mech were fine replaced the motor all good and by the way d1 and d2 motors are different they have different connectors ,I got a replacement from jag rove at Rochester and I know he has another cheers ken
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    Quote Originally Posted by Outback 1 View Post
    he also has a reg
    1996 D1 300TDI GONE
    08 ford ranger c/c
    May 2009
    Tatura, Vic
    What I need to know is what limits it. I have a theory that when it gets to the end of its stroke, currant load on the motor would rise and the BCU would sense this and shut off. Can anyone confirm this?
    What I suspect has happened with mine is the half moon gear has worn right at the end, and this is allowing it to just come out. If this is the case I could fix this with the welder.
    I don't want to waste time trying if it could be another problem, but if anyone can confirm my theory above I will give it a try.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Shepparton
    Quote Originally Posted by Mr Whippy View Post
    You are more than welcome to pull apart one of the windows on the D1 I have sitting at home if you think it will help you. Give me a call.
    Shepparton
    Dec 2012
    PRIMBEE, Wollongong NSW
    Mr Whippy
    you are in luck
    for postage cost i will send you a whole regulator and motor assy if you want for a D1
    i have some old ones that are ok here that won't fir my D2
    they were going to the tip as i had no more use for them
    i have RHF,LHF,RHR,all with motors.
    PM me if you want them
    Paul
    Nov 2012
    penrith
    I found when I pulled off the door trim I pushed the lifters up a bit it went up and down ok but I couldn't go all the way down, and my left front one got stuck up, so I bought new regulators prob solved!!
    May 2009
    Tatura, Vic
    All fixed. I had a better look and found a lot of play in the half moon gear pivot. This was allowing the motor drive gear to ride up and over the last tooth on the half moon.
    I removed the rivet and then welded a piece of 6mm steel with a hole drilled in it to match a half inch bolt. I then cut the bolt to length and peened it over. All play removed, and will never come back.
    I then put a dob of weld onto the end of the half moon gear..
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
