Results 1 to 10 of 13
Thread: 2nd battery and air system
    The back of the Disco is a mess right now. I am hoping it will look a bit better
    when I'm finished. ;-)
    Spent the weekend adding a 2nd battery and installing a new air compressor and
    tank to be used to control the airbags.
    May 2009
    Tatura, Vic
    That will look good when it is finished. What size is the battery?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    It's only a 55a/h yellow top. It doesn't sound big but I have been told it is the equivalent of most larger less quality batteries......and the load I put on it won't be much anyway.
    Quote Originally Posted by walker View Post
    So is that for SLABS or Polyairs? What size tank is that?
    It is for neither. It will provide air for a manually controlled air spring system. I have installed the factory style airbags (with 2" spacers) but I am not using the rest of the factory control gear.
    I had SLS on my last D2 and although I loved the airbags, the control gear and compressor let me down many times.
    Tanks is 4 liters I think.
    Aug 2010
    Bermagui
    Nice work, your truck is looking good. I've been thinking along the same lines for a while now. I've ended up making a fibre glass switch panel in place of the side vent, which is where I'd be putting the controls for the compressor when, and if i ever get around to it.
    Sorry about the pic. Best viewed lying down
    Where did you get the tank from?
    You could even put the compressor in that space, I did on the last D2.
    This setup doesn't even have any switching for it. The compressor is controlled by a 145psi pressure switch on the tank, so it can start up anytime it's needed. Airbags can be raised or lowered from 2 switches on dash and I will also plumb in a line to a socket on the rear bumper for pumping up tyres.
    Lockers are controlled via a seperate smaller compressor under the front seat.
    All the air gear came from Air Ride in Bayswater, Melbourne.
    Nice set up Mr W...
    Thanks Mr. H
    Spent today tidying up and finishing of the air system.
    Tank and battery
    Compressor and valve block. I still need to make a cover for the valve block but the battery, tank and compressor will all be protected once I mount the rear drawer system.
    Air pressure gauge.
    Switches
    Finally a connector to plug in the hose to pump up tyres.
