Results 1 to 10 of 17
Thread: Technical resources for Series 3 Military LR
    Mar 2013
    Hi there forum members,
    I just bought myself a 1981 ex military Series 3. Needs some work.......
    Could anyone give me some advice as to where I can get specifications for the vehicle - books, parts listings etc. Not registered, doesn't run, no clutch pressure at all, no spark etc, so I had it delivered to my local garage first for them to give me a general condition report as it were, and they found out already that the distributor, points, condenser etc are military spec (or so he has advised me). I trust i might come across some more of these idiosyncrasies as I strip it and rebuild it.
    Would appreciate any advice..
    ARN 33-881
    Delivery Plate 42529
    Chassis - LBCAPIAF512779
    Engine - 94131295C
    (if that helps anyone)
    Oh and it apparently has aircraft landing lights for spotlights at the front. which we think is pretty cool if true. 1 is ok, 1 lens has gone.
    Whilst I am here - the car isnt registered but has QLD plates, no papers etc. Anyone had experience of reregistering in NSW - rigmarole or relatively simple?
    cheers all, in advance for any help.
    shaun
    Oct 2003
    Godwin Beach Qld
    G'day Shaunmax
    That looks like a very tidy and complete Series 3 2.6 litre 6 cylinder complete down to the chain/tool box on the front.
    They had a Landrover overhead inlet,side exhaust valve engine,with a syncro 4speed landrover gearbox.the clutch problem would possibly be a failed clutch master cylinder or slave cylinder,the other possibility would that the clutch activating yolk has broken or dislodged (inside bellhousing) the 2.6 litre motor is a little thirsty in the fuel dept.
    The other problem with the 2.6 is that they are hard to adjust the rear exhaust valves and are often not done, this leads to burnt No 5 or 6 exhaust valves,the distributer problem could be coil related or the power to the coil from the ignition switch,I am a long time Landrover owner and have Series 2a & 3 as well as a Range Rover and a Discovery 1
    I am only to happy to help and advise.
    Oct 2007
    wetherill park
    By mil spec dizzy and points your mech means it has a bosch dizzy, points and condenser all s111 army 2.6 had them. They were supposed to be more reliable than lucus
    you will probably find the wiring is all over the place everybody who owned it before you will have added or taken something off
    Western Victoria
    Welcome to the forum.
    Pop over to the REMLR site and have a look. There's bound to be some interesting info there.
    It's good to see ex-army SIII's still with the original motor. I would expect a lot have been Holdenised by now.
    Mar 2013
    Thumbs up
    Quote Originally Posted by UncleHo View Post
    G'day Shaunmax
    Thanks for the feedback UncleHo - An original example was what I was looking for, just didnt think I would have to travel up from sydney to cairns to get it! Says 40oddk km's on clock but i would be surprised if thats the case, we'll soon see. I'm hoping to take it back to the chassis and start from there, i'm sure it will be a long road but up for the challenge. I have been inspired by a few of the forum posts here.
    Quote Originally Posted by THE BOOGER View Post
    Cheers Booger, my mechanic said there was only two condensers in australia for that dizzy! (well that was the feedback he got anyway) surely cant be right?
    RE wiring - I'll have a good look at condition but may look at replacing the loom - on the face of it there doesnt seem to be much out of the ordinary fitted other than the two spots on the front...but I havent had a really good look yet i must admit
    Oct 2007
    wetherill park
    The bosch dizzy is from a 6 cylinder torana cant remember the number but it should be on the REMLR site I would be surprized if only 2 condensors fit I have used vw rotor in mine no probs. The points rotor and condenser can be bought new still so should not be a problem getting spark or you can go electronic I have still looks original but no points to worry about
    Feb 2009
    Hi Shaunmax,
    I'm in Sydney and have parts and advice available. PM me if you need anything.
    cookey
    Aircraft landing lights were popular back in the Sixties and Seventies. I had them on my car as they were much cheaper than anything else.
    I had some in the garage until recently when they went into the bin.
    You should still be able to get the sealed insert, if I recall correctly, they were 100w - two of them (with the rest of the electrical load) used more than the alternators of the time could produce so they'd flatten the battery with prolonged use.
    Oct 2003
    Godwin Beach Qld
    Yup! I will agree with P38arover on that one,those lights did more to destroy alternators than anything else,if you want to fit driving lights,2x55 watt quartz Iodine lights would be plenty,I would also suggest that you fit them up through a relay,also fit a relay to your headlights,as all the power to the lights goes via the switch which in turn results in massive voltage drop and poor lights,Lucas lighting switches were a weak area in the 60/70's you can overcome this by fitting a "New Era" brand (Australian made) double relay as I have done to mine and my Range Rover, quite easy to do the New Era is a double fused relay so no problems there, then just use a Narva mini relay (little black 20mm cube type) for your fog/driving lights,but,you will notice a vast improvement in your lights after just fitting the relay.
    PM me if you want further details.
    I had the same in my RR classic. Last week I noticed I have one of the relays in a drawer in my garage. Hmm, maybe I should fit it instead of the single relay I currently have operating my driving lights.
