Results 1 to 10 of 34
Thread: Dual Battery Install - 2013 110
    Jul 2011
    Hi all,
    I spent most of today installing a dual battery setup in the 110. After a few challenges, I finally got it all done. The basic setup is:
    DBS - Traxide SC160
    Tray - from Devon4x4
    MegaFuse Holder - Blueseas
    Accessories fusebox - Narva
    Batteries - Optima D34's
    (I'm still note sure I'm getting the picture uploads right - so sorry if they are not in the correct order with the comments)
    Here is everything laid out ready to start
    The first challenge was that the Land Rover 'mega fuse' does not appear to be a standard size like ANL. Therefore I had to extend cut the holes out to slots to make it fit the ANL fuse holder.
    I should also explain the only reason I had to change this is because the location of the battery terminal posts on the Optima batteries are further from the battery edge. Therefore the Land Rover 'mega' fuse would not fit. In this picture you can see the difference in size.
    Here is the ANL fuse holder and the Traxide SC160 installed.
    The white wire here is the dash module for the SC160. It allows you to select various modes - winching, jump start, etc. I have temporarily ran this up and stuck it next to the UHF. However I plan to get one of the factory switches (with built in LED) and convery the dash module to look more factory. Tim (from Traxide) provides detail on how to do this if you dont wish to use his supplied module.
    a picture of the completed install.
    cheers,
    Wayne
    n plus one Guest
    Nice install.
    FYI, the Land Rover megafuse is just that - a 'mega fuse', and you can buy holders to suit.
    Also, the LR fuse holder DOES fit on the Odyssey PC1500 battery.
    Just a heads-up for those who come behind...
    Jul 2011
    Thanks for that - I didn't realise the 'megafuse' was an actual standard - I thought it was more a general reference.
    Regarding the Odyssey batteries - yes I found that out AFTER I had bought the Optima's
    Anyhow - so far I'm happy with the Optima's. Will see how they go over time.
    cheers.
    Feb 2013
    Quote Originally Posted by Willow4 View Post
    Hi all,
    DBS - Traxide SC160
    I had posted a picture of the completed install in Blade74's thread and now cant post another copy of it therefore here is the link to the previous post - post #12: http://www.aulro.com/afvb/90-110-130...-choice-2.html
    cheers,
    Wayne
    True to your word mate, this is well done.
    Looking forward doing this to my def 110.
    Sent from my iPhone using Forum Runner
    Mar 2013
    Gymea
    Hey Willow. Top job mate.
    Looking at the tray it looks like you couldn't use the original land rover battery if you wanted to as its closer to 320mm long.
    Guessing it means you are required to buy two new batteries as you have done?
    Are the D34's ok as dual purpose cranking/deep cycle batteries?
    Jul 2011
    Hi Blade,
    correct - you can't use the original LR battery with the Devon4x4 tray. It is built perfectly for Optima D34's or the equivalent Odyssey.
    This is the first time I have used the Optima's and I have heard mixed reviews. But from what I can gather, their success depends a lot on the battery charging system. After speaking to Tim (Traxide) I'm confident this system should be fine. As a dual purpose battery (crank and deep cycle) I understand them to be excellent.
    I'm hoping to finish the install next weekend. Installing the fuse box (for accessories) and running cabling to the rear of the cab.
    n plus one Guest
    Optimas don't like heat either - so they're perfect for an underseat install.
    Shouldn't the leads that run to the dual battery controller have a circuit breaker in them? Also conduit on all the positive leads is wise yes?
    Jul 2011
    Finally ran the power cables to the rear
    Just thought I would add the last part of the install.
    I finally got the time to run the power cables from the battery to the rear of the Defender, install an Anderson plug on the rear bar and install a power board in the back for accessories/fridge.
    First I installed a 50amp circuit breaker in the battery area and then ran the heavy duty cables Tim (Traxide) provided to the rear of the car (all connections to the aux battery are made via this circuit breaker).
    As it takes a bit of effort to run the cables to the rear, I included an additional 4 15amp wires in the conduit for future use. Possible rear work lamps, etc (when funds allow). See below.
    I ran the cables in parallel to the factory wiring loom that runs along the left hand side chassis. Also adding heat reflective foil as per the factory loom where it runs close to the muffler. Sorry - I was a bit slack and did not take any photo's of this work
    Here is a photo of some of the various components.
    Here is the 'power board' case prior to fitting any sockets, etc.
    And here is the electronic gauge. It has the following features:
    - 30 amp
    - voltage (volts)
    - current (amps)
    - power (watts)
    - amp/hours
    - and a few other things
    Jul 2011
    Part way through put everything together. Here is the case with the holes cut out, merit sockets and starting to get the wires made up.
    For additional protection, I also included an auto resetting 30amp circuit breaker in the case. Therefore any/all accessories plugged in can only draw a maximum of 30amps. Here is the case with the circuit breaker installed and the wires going in.
    Again, got a bit slack with taking photos.
    So here is the finished unit installed in the rear of the car on the left hand side near the rear speaker.
    And here it is turned on - showing volts and amps.
    Whilst the unit is always supplying power to the sockets, you can turn the display on or off as you choose.
    The case has two merit sockets and one Engel posi-lock socket. The merit sockets have a switch to enable you to turn power on or off independently while the Engel socket has power constantly.
    The next job is to install the new ARB air compressor
    Oh bugger - more cabling .......
