Results 1 to 10 of 12
Thread: URGENT! Need to borrow some chains
    Ringwood, Vic
    Hey guys, does anyone have a set of chains I can borrow for this w/e? I don't care what size, just need them in the back in case I'm pulled over at Hothm on the w/e..... they won't get used as there's no snow.
    I live in forest Hill, so anywhere out this side of town or across to the North would be great....I need to pick them up from somewhere around midday.
    Hope someone can help
    D4 SDV6, a blank canvas
    Aug 2009
    Sunbury Victoria
    I've got a set you can borrow Alan. Only problem is there in Sunbury and I don't start work until 3pm so can't drop off. If you have no luck you can come past and pick them up. It's pretty easy to get to the Hume from here. The size I have would fit your wheels if needed.
    On a side note: check if a 4wd needs to carry them this time of year.
    Cheers, David.
    My Land Rover has made me a better Mechanic........
    D2 TD5 Manual, CDL, Detroit Rear, Truetac Front, 2" OME lift, 32" MT Tyres, ARB Bull Bar, Winch, TJM Roof Rack, Driving Lights, Dual Batteries, ARB Side Steps, Rear Draws, Uhf.
    Ringwood, Vic
    Thanks mate, can you leave them somewhere I can find them please, I'll let you know if not required....oh, you can sms an address if you like lol...0417367625
    Scarborough, QLD
    Being a QLDer, I'm probably not the best to offer advice, but I understand 4WDs are note required to have chains.
    Ringwood, Vic
    Quote Originally Posted by Ranga View Post
    ALL vehicles entering the alpine areas of Victoria are required to carry chains and fit them when instructed.
    It's a good rule.... except there will be no snow for at least a week yet
    Aug 2009
    Sunbury Victoria
    PM sent.
    Cheers, David.
    Wandiligong Victoria
    You will need to carry chains.
    You can buy parking tickets a bit cheaper online here Mount Hotham - Resort Entry instead of paying up the top. My recommendation is to keep going and have lunch at the Dinner Plain Pub and then return to Bright. This way you can have a play in the snow when it comes and you don't have to pay for entry. The system is "Suppose" to log you in and out of the village. It gives you enough time to pass through for no cost. Fines are big and plentiful and not always correct!
    You will be able to see the devastation that was the Harrietville fire and the desecration that is the clean up. Don't forget to get some Alpine diesel in bright before you head up. I recommend the BP in Bright. There will be snow on Feathertop and Bogong and if lucky enough at Hotham to build a snowman Hotham Heights weather forecast, Bureau of Meteorology Warnings & rainfall
    Apr 2013
    NSW, Sydney
    True in NSW, but not true in Vic as others have said:
    Regulations
    Although two interesting gotcha for the NSW fields:
    "Chains may also be required in certain weather conditions" - so if you don't have them in a 4wd then you can't go though, whereas a 2wd with snow chains could.
    Apr 2010
    Emerald, Vic
    Should have went to Aldi last saturday. $40 for diamond pattern 4wd chains. There is always next year about this time.
    Ringwood, Vic
    Quote Originally Posted by Gillie View Post
    Thanks Gillie, I know Hotham/Dinner Plain pretty well. Friends have a place there. Only staying for the long w/e but since there's no snow, the Cobungra River might get a try for a trout
