Thread: Learning Access 2007 - help ?
    Bracken Ridge, Qld
    Trying to make a database to learn how to umm make databases.
    Am using the Assets template in Access to base my database on - try to learn how things are set up.
    I naturally keep coming across obstacles and am not necessarily sure what I need to ask the help thingy.
    What's the best way do you reckon -
    1. Persist with the Microsoft Help Thingy
    2. Use this free online training resource... (please specify)
    3. Get a copy of that MS Access for dummies book. (and If I do should I get the 2007 one as we use that at work or the 2010 one which I use or at least have, at home). If I get the 2007 one will that all work in 2007? Vice versa? At the moment I don;t think I'll be doing anything too challenging to the system.....
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Bracken Ridge, Qld
    gone
    1996 Discovery 1
    current
    Nov 2010
    Adelaide
    2007 and 2010 are quite similar to use.
    The reason why Excel is the world's favourite database is its easy to add and manipulate data. Unfortunately it struggles with quries combining the contents of several tables. It also can end up being resource hungry, a 80MB spreadsheet I converted ended up at less than 800K, with all sorts of bells and whistles, in Access.
    Access is hard to learn, you need to have some form of programming bent to get the most out of it. Once you have an application, however, any dummy can use it without fear of breaking something (as they can easily do in Excel), data entry is throufgh forms, can be validated etc. Queries can be used to extract information, formatted in the way the designer intends.
    If you are prepared to put in the yards you will find Access to be a good product. If not, you'll find it to be daunting and ultimately frustrating.
    Bracken Ridge, Qld
    So far I'm in the "daunting and frustrating" mode.
    gone
    1996 Discovery 1
    current
    Nov 2010
    Adelaide
    One of the keys to using a relational database is to create your data structures at the beginning, before you start enterring data. You will need to normailise your data. In effect this means working out what data might have repeated values and moving these to their own table.
    Decide what format each data will be stored in, I try to limit the number of data types to avoid the data mismatch errors. Odd as it seems, store numbers as text unless you have to perform calculations. This applies particularly to things like postcodes.
    Once you have created your base tables you can create lookups for repeated items that have been moved to another table. For example, If you have decided to keep an adress table seperate to personal details (a person can have more than one address, and an adress can be used by more than one person so it can be repeated) you can ctreate a lookup for home address, another for delivery address, another for invoice address etc, that all point back to the address table.
    Once you have your tables you can create data entry forms based on the tables. The forms can add data to different table if necessary. For example, a personal information form can be linked to tblPerson (personal information) and tblAddress.
    HTH
    Bracken Ridge, Qld
    Increasingly thinking I'd be better of spending my time screwing a corkscrew into my eyeball as opposed to this.
    gone
    1996 Discovery 1
    current
    Mar 2011
    Burpengary, QLD
    G'day!
    I've been playing with Access database for years, from "Access 97" onwards. I've never needed more that the internet for help and examples of what I've wanted to do. My ongoing database creation is the main tool in our team at work for work flow and document management, and has lots of funky automation and integration into emails, etc.
    My advice is to just keep playing, and the internet is definitely your friend...
    Cheers!
    Michael.
    Mar 2007
    South Arm, Tasmania
    Vlad,
    I've got an "Access for Dummies" type book in electronic format (38 mByte). I also have the same for MS Project, Excel & Word, plus AutoCad).
    If you want a copy - PM me an e-mail address and I can send it to you via a download link for big files.
    All the MS books I have are for 2007 version - but the principles are still the same. I'm currently trying to get my head around databases as well - not bad on Excel but a lot of what I have been doing for years in spreadsheets really should be in a database, and our work is moving in that direction as well, so I suppose I have to catch up.
    Cheers .........
    BMKAL
    Nov 2010
    Adelaide
    Sent a PM instead...
    May 2002
    Heathcote (in "The Shire")
    Quote Originally Posted by VladTepes View Post
    I'm not a database person, although I have dabbled with access over the years. I was never able to use the sample databases to learn as I needed to have a target to work towards, and something that I could at least have an appreciation whether the results being returned looked feasible.
    One thing though - you need to know what you want out at the end, to determine what you need to collect at the start.
    Martyn
