Hi James, as far as I know the only way to get them is through Gordon(gghaggis on here) at Green Oval Experience.
Green Oval Experience Land Rover resources
Hi everyone,
I have a MY13 Disco 4 HSE and want to be able to equip it more for some four-wheel driving.
I opted for the new 20" black pack, which looks great for the road, but I don't want to venture into the muddy ruts of off-roading with them..
So, has anyone purchased the 18" compomotive rims for their Disco 4 and how did you guy about ordering a pair? Where is the best and cheapest place to order?
Also, before i order, is there anything I need to know about the wheels?
James
Last edited by TerryO; 5th August 2013 at 01:33 PM. Reason: To be moved to D3/4/RRS section
Sean
We purchased 6 of these wheels from Gordon last year and he was very good to deal with. Delivery was a bit slow as I think he waited until he got a container full.But we had plenty of time and it was not a problem.
It was a very positive experience to deal with such a knowledgeable retailer on not this matter but all sorts of issues.
We put our own original centres in when we fitted the new rims and by the time we got to Birdsville they had been spat out. A bit of plumbing sealant would hold them in a bit better but we bought another 4 in Perth and just ran the 18's without the centres.
Gordon also recommended various tyres for these rims which included the BFG All Terrains. As my own experience with the BFG All Terrains has always been good, we went with them.
I would have to say that they are really just a bit too big in diameter once fitted as they rub on the plastic front guards at the access setting and on anything like a full lock.
It totally gave me the irrits that the only way I could get the spare in to the under body cavity was to deflate it. Even so it still takes a rubber mallett and some decent whacks to get it in, even after you remove the stone shield at the front of the cavity. Def a two man job to get the wheel up as its not possible to keep a load on the cable and lower at the same time but that is the case with the standard wheels as well.
We were very pleased to have made the move to the 18's and the big sidewall tyres. No tyre troubles in over 18000 k's.
Steve L.
GOE 18" rims transform an outstanding offroad vehicle into an absolute weapon.
I run two sets of tyres and rims....factory for around town and GOE rims and more aggressive tyres for play.
If you were to check my GOE rims, you will see they have been hammered.....don't want to do that to the expensive factory rims.
One of the best investments you can make....it just gives you so much more confidence.
Brett.....
There are quite a few 18" rims for sale on Eblag (mostly off RRS) not too expensive either.
HTH
Ivan
Sorry, should have added that they also fit the D3 petrol V6.
Fuji white RRS L494 AB Gone
2023 Ford Ranga
You can also order them from the UK and have them delivered directly to your door. I ordered a set from Rory at Performance Alloys in the UK (Compomotive PD1880 Wheels | Compomotive PD1880 Alloys | Performance Alloys.com ® The Alloy Wheel Experts). He was extremely helpful and you can see the price for yourself... delivery was 425 pound for air freight and courier delivery directly to my door in Darwin.
Make sure you specify that you need the rims with the ET44 offset. VERY important.
