Results 1 to 10 of 16
Thread: tyres and towing
    Nov 2007
    On the road.
    Question tyres and towing
    theorectically which would you prefer for extended touring towing a 1900kg pop top with a d2 td5 manual?.
    235/85/16LT muddies or 245/70/16LT all terrains.
    noting the standard size on a d2 td5 is 235/70/16.
    Apr 2012
    Orange, NSW
    The all-terrains....
    Why do people put muddies on camper trailers?
    If they're not providing drive, wouldn't an good, strong set of ATs be enough?
    Just seems like a waste of money to my mind but then again so does towing off-road
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    May 2003
    On The Road
    exactly the same size as the tow car
    Feb 2012
    Parkdale, Melbourne
    Well the taller (larger diameter) the tyre the worse your fuel economy will be, so I wouldn't go crazy if you're towing. You could change ratios, but it's another job to do.
    BTW, I assume you mean for the Disco, not the trailer.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Nov 2007
    On the road.
    to clarify yes i mean on the car, not the van.
    Apr 2012
    Orange, NSW
    Quote Originally Posted by Yorkie View Post
    Well in that case, depends on where you're going.
    I might, Yorkie Need to find some rims for them first
    I would never do extended touring on muddies, specially not towing two tonnes. You are likely to be spending a fair bit of time on the blacktop and the muddies will be noisy and with two tonnes on behind, suicidal in the wet on the bitumen. Get a good set of ATs
    and the continual increased torque loading of towing will destroy the tread blocks.
    Nov 2007
    On the road.
    Appreciate comments so far, will hopefully pickup the van next week from Gold Coast so the run back on the muddies will give me some idea which way I will go.
    Ellendale Tasmania.
    I though our model D2 had 245/70/16 as a standard tyre size
    Anyway a 1900kg van will be tough on your D2 with 235/85s, trust me I know, our 1500kg camper was enough for our D2 on 235/85s, add the wind drag of a van and well, could be a bit of a task.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
