Results 1 to 10 of 18
Thread: Dual battery diagram
    Aug 2012
    Hello, So I have the spare battery from my D3 and the isolator thingy SC80 , basically everything that was under the Bonnet, ( I left all the tricky wiring that runs through the firewall and to the sockets )
    Now I need to get a shopping list together for Drivesafe
    What do I need?
    Where is the best spot to run the cables to the 12 volt sockets
    New car BTW
    Kingston, Tassie, OZ.
    Quote Originally Posted by herrBlick View Post
    What do I need
    New car BTW
    Just ask Tim for the Defender wiring harness part, you can PM him a question, he doesn't bite
    JC
    Aug 2012
    I was just off the phone with him .....It's not the harness that's the problem it's the way 2 run the cable,
    Do you go under the car or behind the plastics Allah the Discovery ... I am clueless as to what to do .....
    I need some Diagrams
    Jul 2003
    Congrats on the acquisition....nice!
    So where are you putting the battery and where and how many 12v outlets are you installing?
    Mahn England
    Ex 300Tdi Disco:
    Central Coast NSW
    Run the cables through the large grommet in the battery box, underneath the car, along the near side chassis rail to about equal with "C" pillar.
    Bore a hole under the rear seat, there is a nice flat section near the bottom of the "C" pillar. From there run the cable up the pillar, then you will need to remove the trim around the rear sliding windows. Mount the 12v plugs in the window surround trim, hide the cable in there as well. Re fit and your done
    Who needs a diagrame
    Aug 2012
    Quote Originally Posted by one_iota View Post
    Ok cheers mate
    I am want to put 3 12 volt outlets just to be sure , I only ever use my fridge and Travel buddy oven but a spare for some LED night lights or other appliances would be good ,
    I am a neat freak though so the tidier the better.
    Loving the Defender thus far .....It's the first manual,I have driven so I am finding it tuff going
    Jul 2003
    This is what I did:
    http://www.aulro.com/afvb/projects-t...rear-puma.html
    There are many ways to skin the cat though.
    Good luck with the manual change learning curve...it's worth it.
    Mahn England
    Ex 300Tdi Disco:
    Tangambalanga
    Two things HB, if you go to my build thread, there's a couple of pics there which may help for the battery install. I used Traxides 160 unit, and so far,, very happy with it. And when it comes to electrics,, I'm a nuff nuff
    The other thing, as your in Melb,, oh look at that, just like me , depending on where you are, you can have a look at mine in the flesh. This could also be achieved at the 65th Anniversary on the 29th(?) event at Scorsby too
    I took my outlet cable under the floor pan as suggested and came up behind the rear passengers seat, but mines a ute, so you'll probably want to do it differently.
    Aug 2012
    Thank you all for your help I kinda got it now . I am writing a email to Tim as we speak , as you say there are many ways to skin a cat,
    I think easy access is the key and also tidiness
    don't forget with a defender simplicity is king!!
    are you enjoying driving it yet?
    jc
