Results 1 to 9 of 9
Thread: radio gear in what sort of land rover
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    this sort of radio was fitted to what sort of land rover?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jan 2013
    Penrith
    some names and numbers off the back plate would be good if there still on there, could then establish at least who made it
    East-South-East Girt-By-Sea
    1.20 MB
    "Larkspur" C42 VHF set and power supply, late 1950s through 1960s in Aus until we migrated to the US Vic 1 stuff.
    You need 24V
    That would be good for someone restoring a Ferret, SII or early SIIa FFT.
    It has a commanders headset and control which is more appropriate in an armoured vehicle, although the ATU (with it's special bolt) is a B vehicle (soft skin) fitting. They go out on the front mudguard, the armoured cable is the coax ext for the ATU box, it runs down and under the outer edge of the front door sill, under the firewall and up under the mudguard where it pops out through a special plate to connect to the ATU.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    thats what i thought but wasnt anywhere near sure...
    i just knew it looked like what was supposed to be in my CR as it originally had one apparently.... or so i am told.
    May 2012
    Perth, Northern Suburbs
    Just looking at those cables and remembering having to rub spit on all the 'o' rings to make them go on to the radios etc is bringing back nightmares! What a pain they are!
    1.20 MB
    Quote Originally Posted by incisor View Post
    If your SII CR was fitted with that, there should be evidence of the rectifier which sat above the front cross-member in front of the radiator. There would be bolt holes or posts on the cross member.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    there was the remains of an angle iron post originally... hmmmmm
    there is a hole in the rear bulkhead and behind the passenger seat for cabling to run as well.
    1.20 MB
    Sounds like the real thing.
    The regulator/distribution box sat on the transom between the front seats, in later models there were two small electrical boxes behind the passenger. One of these was the regulator for the 24V generator.
    In the mid 1960s FFT there was a blower to keep the power supply cool. This had a little louvered panel just behind the fuel filler on the RHS.
    If you wanted to make everything work, I wouldn't bother with the original system, I'd fit a 24V alternator off a 24V MQ Nissan Patrol or similar.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    what sort of money these things go for?
