Results 1 to 6 of 6
Thread: FIRST LOOK !!! D1 TDI 300 DUAL ALTERNATOR
    oztrax Guest
    So whats different about my dual alternator install ?
    Well i kept aircon compressor on original mount but still drive 2nd alternator off aircon 4 groove poly belt.
    And..... cost about $100 AUD
    regards
    OZ
    Kingston, Tassie, OZ.
    Well done mate! i have thought about a designated alternator for a welder in this position before, you have done a really neat install!
    jc
    St Helena,Melbourne
    4.28 MB
    Good spot for onboard air also .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    oztrax Guest
    arb comp
    agreed my locker compressor fits behind the relocated
    coolant tank and fuseholder
    its the little fella though
    ok, but why?
    Theres one thing Id pick
    you need to make the bracket a Y bracket so you pick up more than one of the timing cover bolts.
    good install though, I might revisit the layout I was going to do to fit the endless air to SWMBOs disco.
    oztrax Guest
    i agree BK
    the aftermarket alt mounts do have the "y"
    shape you speak of
    and i had to tighten alt mounts quite firm to
    reduce belt vibration. my stay is made of stainless
    though, used it coz it was lying around 5 mm by 25 mm,
    alternator is off mitsubishi L300 60 amps,
    $50 from wrecker chose as i used it As primary alt whilst
    awaiting a new 100 amp marellli. The L300 unit had the closest
    front end arrangement to fit in primary brackets with same
    shaft/pulley xtension.
    In othe words its a small light Alternator but will fit
    in either position
    regards
    Oz
